Old January 25th, 2007, 10:18 AM
sandalwood36 is on a distinguished road
Question Frigidaire Gallery Side by Side flooded kitchen
I'm at work & don't have the model number with me but was hoping I could get some insite into my fridge problem.
Had ice maker replaced after approx. 2 years.
Experienced much discussed leak in bottom of fridge after that...
In-door water dispensor also leaked.
Hubby turned off water to indoor ice & water dispensor.
Eventually had repairman fix fridge leak.
Water dispensor continued to leak (hubby turned water off again).
Freezer leaked after that. Hubby was disgusted so we manually de-iced the bottom of the freezer for over a year. Water remained off...
Finally brought in a repairman to fix freezer & water dispensor leaks.
Freezor leak stopped & water & ice dispensor worked fine all day (during large party). Same night, was awakened by screams when mother-in-law discovered water pouring out of in-door dispensor! Kitchen & basement were flooded! Hung over hubby spent hours vacuuming up water!
Water is now off for what he says is forever & I can't really blame him!
Really miss convenience of ice maker & in-door dispensors though.
Any idea why the water would suddenly "pour" out of the water dispensor?????
Also, is there a way to leave the water on for the in-freezer ice maker but not have it go to the door????
Old January 25th, 2007, 08:43 PM
You have 1 of 2 things causing the front dispenser to flood like that.
Either your water inlet valve in the back of your refrigerator where your water supply hooks up to is bad, or your dispenser switch is sticking on.
To test the water inlet valve, you will need to pull the refrig. out from the wall, take off the back lower access panel, dismount the water inlet valve from the cabinet, then take off the larger of the two plastic water tubing lines from underneath the water inlet valve, then unplug the electrical connector from that side, then turn on your water supply, if water pours out then your water inlet valve is bad.
Please post your model, we will need it to continue.
Old January 26th, 2007, 03:55 AM
Default Frigidaire Gallery Side by Side flooded kitchen
Thank you Jake... I will ask my husband to check the water inlet valve.
Honestly don't know if he'll ever agree to turn the water back on though.
It would be good if we could somehow have the ice maker work without turning on the in-door dispensors...
Old January 26th, 2007, 04:01 AM
Model is: Prof. Series FRS26ZSH...
When we do replace this lemon, what make would you suggest we buy???
Thanks again for your prompt response!
Old January 26th, 2007, 10:30 AM
Looks like your model was made in 1999, so its about 8 yrs. old, you can now replace it anytime since most only last 8-15 yrs. now anyways.
I would recommend Whirlpool or Kenmore made by Whirlpool(model# starting with 106.)
Frigidaire side-by-side fridge side not cooling, but freezer side is Jason K Frigidaire/Electrolux 7 October 27th, 2006 06:39 PM
How to replace timer switch on Frigidaire side by side refridgerator Pfaffy Frigidaire/Electrolux 7 June 14th, 2006 09:15 AM
frigidaire side by side exterior leak doctorvik@hotmail.com Frigidaire/Electrolux 1 November 7th, 2005 08:19 PM
Frigidaire side by side leaking on FF side sacju Frigidaire/Electrolux 3 October 24th, 2005 11:25 PM
Water leaking from side by side Frigidaire goldmonkeyking Frigidaire/Electrolux 3 August 23rd, 2005 04:03 AM
