My PLDB998CC0 won't drain or clean the dishes very well, at the end of the cycle there is a lot of water covering the heating element. I checked the main (big) motor and impeller and all looks fine, no broken parts or blockage. I put 110VAC to it and it spins really good. I checked the (small) drain motor and it also seems to check out well. The drain hose is fine with no kinks.
Sometimes when it runs the it will take a while to water to start filling the tub, there will also be times when it is difficult to enter settings. Any advise on what to do next? It's just over 5 years old. Thanks. |
Jeff has a good troubleshooting page here you can look over: http://www.applianceaid.com/frigidaire_dishwashers.html Jake
Thanks but this just talks about faulty impellers and pumps which does not appear to be my problem.
Do you have any other advise? John Scholz |
The water shouldn't be covering the element when you open the door to look in, so I would first take your drain hose off from under your sink, get a bucket and put your drain hose in it and start it in drain, it should have a good strong flow, does it?
You may also have a bad control board if its not going into the settings sometimes. Jake
| Maytag MDB5100AWW leaking, won't cycle or drain | Chailena | Maytag/Magic Chef/Admiral/Jenn-Air | 8 | April 21st, 2007 11:34 AM |
| MDB6600AWW won't drain | Bat123Man | Maytag/Magic Chef/Admiral/Jenn-Air | 3 | February 15th, 2007 07:56 PM |
| kenmore 665 16831792 won't drain | Hardly Working | Sears Kenmore | 6 | February 5th, 2007 10:32 PM |
| Maytag DWU8530AAX Drain and clean issues | route62 | Maytag/Magic Chef/Admiral/Jenn-Air | 3 | July 24th, 2006 11:44 PM |
| Another Whirlpool Dishwasher won't drain | rickm | Whirlpool | 1 | August 8th, 2005 10:11 PM |
