Old April 22nd, 2007, 03:37 PM
atari_400 is on a distinguished road
Default Frigidaire PLD3450RDC1 "Er" Flashing Error
Can anybody tell me the reasons for getting all lights on the front panel flashing with "Er" in the display ?
I cannot press anything on the button panel that will clear the error.
I have cycled power and get "PF" (power fail) as normal, but once I clear "PF" by pressing cancel I get the flashing again.
Any help appreciated.
Old April 23rd, 2007, 08:01 AM
According to Epinions, this is a common problem that has caused numerous people lots of issues. It seems the electronics may be a susceptible to moisture from the washer itself.
Does anybody know if this is true ?
Sorry for the typo. The model # should be PLD3460RDC1.
Old April 23rd, 2007, 10:14 AM
Yes, they have had some issues with the electronic control board doing this.
You would need a new one, you can order it here:
Old April 23rd, 2007, 10:17 AM
Thanks.
I am going to try and work the extended warranty first.
However, being as I am the second owner (but within the extended warranty period) they may be sticky.
Is that replacement circuit board the same as the original or improved in some way to counteract the problem ? If not maybe it's worth spraying on Humiseal to prevent moisture ingress.
Old April 25th, 2007, 10:55 PM
They improved it.
Frigidaire flashing #4 all the time Ranndyb Frigidaire/Electrolux 14 August 12th, 2007 09:02 AM
Kenmore oven C970-688082 cooktop refuse to start with error code "F5" then "Er" pprevill Sears Kenmore 1 March 18th, 2007 05:18 AM
Frigidaire ATF7000ES Front Load Washer E10 Error nookerdude Frigidaire/Electrolux 3 November 13th, 2006 09:51 PM
dE (Defrost) Error flashing AlexS GE/Hotpoint 1 July 23rd, 2006 09:08 AM
