June 8th, 2007, 07:25 AM
No spin but a loud buzzing!
I have a 10 month old Frigidaire front load washer(MOD: LTF530DS) that refuses to go into the final spin, does not drain and makes a very loud buzzing. (I have read almost every thread on the "NO SPIN" problems and have not seen the loud buzzing problem)
The door light stays on during this time.
Runs all other cycles
Problem occurs when I attempt to start in spin mode also.
Repair through Lowes is two weeks out.
Any thoughts??
June 8th, 2007, 10:39 AM
Its either your door lock latch assembly or your water pump is clogged.
I would check the water pump first, but since its still under warranty, its better that you not do anything, it could void your warranty.
Contact Frigidaire to see if another authorized servicer can come out sooner.
By kevin rowland in forum Sears Kenmore
Last Post: June 15th, 2007, 10:20 PM
By problems in forum Maytag/Jenn-Air Reviews
Last Post: February 15th, 2007, 09:11 PM
By k5er in forum Sears Kenmore
Last Post: September 13th, 2006, 11:58 PM
By AllyT in forum Sears Kenmore
Last Post: July 4th, 2006, 09:50 AM
By homeboy in forum Frigidaire/Electrolux
Last Post: June 20th, 2005, 07:14 PM
