Old July 7th, 2007, 11:42 AM
griffon is on a distinguished road
Default Frigidaire Dryer Model #FEQ1442CES0-Only turns when selected to no heat
My electric dryer just quit working. When I tried to turn it back on, it wouldn't. If I select "no heat" the drum will turn. If I select any heat setting, the drum will not turn and I get flashing lights. I tried reading the codes and got an error code of 95. I have no reference to this code. Following a repair book and on-line sites, I have tested the Safety Thermostat and the Thermal Limiter. Both have 0 ohms. I tested the Control Thermistor and, according to the wiring diagram, should have go about 50 k ohms. I got 58 k ohms. I am guessing this is normal. What could be wrong
Old July 7th, 2007, 12:23 PM
Default More Troubleshooting
I took apart the control panel. Heater relay #2 and the red wire going to it were melted some. Maybe this is the problem?!!
Old July 7th, 2007, 11:52 PM
Take off your bottom access panel in front below your door, there should be a service sheet on the inside cabinet that will tell you what that error code means.
They have had some problems with the main control board on these models.
Part#134484212
Kenmore Dryer turns but no heat crawdad77 Sears Kenmore 1 May 26th, 2007 09:09 AM
Frigidaire Dryer Heat Issues jakemidd Frigidaire/Electrolux 5 May 24th, 2007 10:53 PM
frigidaire gas dryer no heat - how 2 test parts? peanut3122 Frigidaire/Electrolux 4 December 1st, 2006 11:08 AM
Heat is intermittent on Kenmore Elite Dryer (model 110.60092991) mikefromottawa Sears Kenmore 8 June 14th, 2005 06:05 AM
Frigidaire electric dryer - intermitent heat johnq Frigidaire/Electrolux 1 June 7th, 2005 07:03 PM
