Old December 8th, 2007, 09:01 AM
jtchief is on a distinguished road
Default Frigidaire Model PLEF398ACA - F7 Indicator Message
I am getting the F7 message on a Frigidaire Gallery range with constant beeping. Where do I start?
Thanks for your help!
Old December 9th, 2007, 05:40 PM
This just started happening out of the blue? You weren't using your oven or using the self-clean cycle?
F7 is a EOC(electronic oven/clock control) failure.
Manufacturer part#316207600 is RepairClinic item#937801
Check your owners manual, some models have up to a 5 yr. parts warranty on electronic parts.
Old December 9th, 2007, 05:53 PM
Thanks for the confirmation. That is what I suspected after checking your link to the tables of fault codes. I just wanted to make sure before ordering the replacement.
To answer your question, yes, it did start happening out of the blue. In the middle of the night the beeping started at random. Then in the morning, it went crazy beeping and flashing F7. We had not used the stove nor the oven for about two days. We had not run a cleaning cyle in quite a while either.
I checked the manual and the 5 year warranty is only applicable to the glass smoothtop, seal and heating elements for this model.
Thanks for the link to the part. I have ordered from them before and they have extremely quick service.
Thanks again!
jtchief
Old December 9th, 2007, 09:18 PM
Sounds good jtchief, yes then if it just started happening in the middle of the night without using it, its that control board thats bad.
Please help with Frigidaire model numbers Bruce Humphrey Frigidaire/Electrolux 1 November 29th, 2007 04:25 PM
Frigidaire Model PLEF398CCD Oven Not Working fmlynn Frigidaire/Tappan/Electrolux 2 September 30th, 2007 09:53 AM
Frigidaire Model #GLEF378ASE Electric Oven temp problems sockeyehigh Frigidaire/Tappan/Electrolux 4 June 2nd, 2007 07:36 AM
Frigidaire Model PLEF398ACA - Hot Element Indicator Message jtchief Frigidaire/Tappan/Electrolux 3 May 11th, 2007 08:01 AM
Frigidaire side by side model #FRS26R4AW7 ailina1213 Frigidaire/Electrolux 3 December 22nd, 2006 09:33 PM
