Old December 27th, 2007, 12:21 PM
Senior Member
sun45 is on a distinguished road
Question neither elements in oven come on, no power to elements
i have a fridgidaire smooth top model # FEFL74ASF. Everything is ok on top. But when you set it to bake or broil neither element heats up. i tested the voltage and when you set it on either bake or broil there is no power going to the elements, There are no error codes on the display. Please advise.
Old December 27th, 2007, 11:23 PM
Then the problem would be in your electronic clock control board.
Manufacturer part#316207511 is RepairClinic item#1036364
Old December 28th, 2007, 04:13 AM
Senior Member
what go wrong with them is there ny way to fix them?
Old December 28th, 2007, 10:44 AM
Nope, its all internal. I don't know what causes them to fail, but I've changed tons of these in the last 10 years.
Frigidaire Single Wall Oven Model# FEB30S7DCB, went blank msarbpd Frigidaire/Tappan/Electrolux 4 November 28th, 2007 11:34 AM
Whirlpool Super Capacity 465 / Gas Oven jeff_465 Whirlpool 4 November 25th, 2007 12:26 AM
Fridgidaire oven doesn't work F3 Code shermar Frigidaire/Tappan/Electrolux 3 December 31st, 2006 08:14 PM
Whirlpool Oven #RS696PXGQ2 Elements Don't Heat CCSnively Whirlpool 4 July 26th, 2006 10:34 AM
