Old April 15th, 2008, 04:47 PM
whiteoak is on a distinguished road
Default Frigidaire Classic Seires
I have a Frigidaire Classic Seires model# 316233860 . First I had a F9 error when trying to preform a self cleaning. I took the back panel off and checked the wiring it looked ok. I powered on and held down the Clear/off button and then I received 100 and door locked. Now it has the time and says door locked the timer buttons work but none of the "Bake" or other buttons work the range also works. Help me Jake!!
Old April 15th, 2008, 09:31 PM
Please check your model# again, I can't find any info on that one. The model# tag is usually located on the bottom of your range after you pull out the storage drawer on the bottom frame.
So, now it says locked and the oven door isn't not locked?
Did you try to unplug it or turn the breaker off to it for 5 minutes to see if it will reset?
Old April 16th, 2008, 04:34 PM
Default correct model
Here is the correct model number FEF366CCB . I turned the braker off and now I get the F9 error again.
Old April 16th, 2008, 08:57 PM
Here's the tech data sheet for your model:
ftp://ftp.electrolux-na.com/ProdInfo...16218513en.pdf
F9 says:
Control has detected a problem with the Motor Door Latch Assembly.
Check the wiring. Replace the Motor Door Latch Assembly if necessary.
You will need to order a new latch motor assembly, here's the one for your model:
Manufacturer part#316464300 is RepairClinic item#1191763
316464300
Please help with Frigidaire model numbers Bruce Humphrey Frigidaire/Electrolux 1 November 29th, 2007 06:25 PM
Black grease smudges on clothes - Frigidaire LEQ332DS0 dixieagle Frigidaire/Electrolux 1 July 23rd, 2007 02:37 PM
Frigidaire Double Wall Oven or Repair Existing GE Wall Unit knittermom Frigidaire Brands Forum 5 February 8th, 2007 11:39 AM
Wiring for my new Frigidaire mgoogs Frigidaire/Tappan/Electrolux 5 December 7th, 2006 05:50 AM
Frigidaire Classic (PN316218504 (0301)) Broiler Flame is Low amgc230k Frigidaire/Tappan/Electrolux 1 October 23rd, 2006 01:40 AM
