Old June 24th, 2008, 07:13 AM
Rachel is on a distinguished road
Default F31 Error on Tappan
I have a gas range that's less than 2 years old. After a power outage my EOC went black. After a second outage two weeks later, it mysteriously blinked back on. Most of my EOC controls are functional (clock, timer, oven door lock). But when I try to turn on the oven- it starts fine, then after a few moments I get an F31 message.
Old June 24th, 2008, 08:33 AM
I couldn't find an F31 failure code for Tappan. An F1 failure code is the electronic control. An F3 failure code is the sensor. Check the sensor first. Use an ohm meter. You should have 1100 ohms at room temperature.
Old June 24th, 2008, 09:21 AM
Whats the model# of your range? Its located either inside the oven door, or on the very bottom frame in the front after you pull the storage drawer out.
Old June 24th, 2008, 11:54 AM
Model No. TGF351ESC
I'll look into acquiring an ohm meter, but display definitely reads F31.
Old June 24th, 2008, 01:34 PM
The error code F3 is pretty much a universal error code for every brand. Tappan was owned by Maytag, and under Maytag I found an error code F3-1 which is also an error code for the sensor. I would start there by checking the sensor first.
Old June 24th, 2008, 03:25 PM
Here's the oven sensor probe for your model:
Part#316217001
You would need to pull your range out from the wall, then take off the back access panel, then you'll see the connector for the sensor probe, just unsnap the connector and ohm the sensor.
Unplug your range first before taking the back access panel off.
Tags
f31, tappan
Tappan gas range wont heat xghobo Frigidaire/Tappan/Electrolux 6 June 22nd, 2008 08:27 PM
Electric Range - F31 error zdawg Sears Kenmore 3 November 19th, 2007 05:25 PM
Tappan fabulous 400 elijdub Buy, Sell or Trade 0 August 4th, 2007 04:21 AM
Nearly free: Tappan Fabulous 400, Gas machmer Buy, Sell or Trade 2 July 10th, 2007 07:38 AM
Tappan RaderRods Antique and Retro Appliance Chat 1 March 19th, 2007 04:30 AM
