Old November 16th, 2008, 05:11 PM
edcasey is on a distinguished road
Default [FIXED] Frigidaire Gallery bake oven wont light
I have a Frigidaire Gallery model NGSG3PZASC that the bake oven wont ignite. Broiler and stove top burners work fine. This is the 3rd time I've had this problem. The first time I replaced the gas valve and it worked for two years. Than it developed the same problem so I replaced it again. This time it stopped working after about six months.
What happens is the igniter glows and the gas valve only partially opens. Not enough to ignite but you can smell gas. If I lightly tap anywhere along the gas system (regulator, gas valve or burner) it will light with a normal flame but wont reignite when it needs too.
I checked the igniter with an amp meter and it is drawing 2.69 amps. I see from previous threads that this is low. What I don't understand is if the igniter is bad than why does it ignite when you tap on it. Or do I have 2 problems. Thanks
Old November 16th, 2008, 07:01 PM
The problem is your oven igniter glow bar, I'll guarrentee that if you order it and change it your oven will work like new again.
Here's the cheapest oven igniter glow bar I found for your model you can order:
Manufacturer's Number: 5303935066
5303935066
Jeff explains it here:
You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
Courtsey of http://www.applianceaid.com/gas.html#glow
Old November 16th, 2008, 07:08 PM
Thank you for your quick response. I'll definitely order it. It would be great to be able to cook this Thanksgiving.
Old November 16th, 2008, 10:06 PM
Yes, Thanksgiving is coming fast, just 10 more days.
Keep us posted when you install it.
Old November 18th, 2008, 05:42 PM
Ordered the igniter Sunday night and received it today (Tuesday). I installed it which should have been very easy but both screws broke. I removed the burner and was able to get the remainder of the screws out. Installed new screws and wired. The igniter heats up much faster and glows much brighter. Sure enough the gas valve opened fully and the oven lit. It also got to operating temperature faster than it ever has. I definately consider it fixed. Thanks for your help Jake!
Old November 18th, 2008, 08:08 PM
Excellent Ed, good job, glad its running better than ever now.
Looks like a Happy Thanksgiving at your house with a "working like new" oven.
Whirlpool electric range - Oven (Bake light) does not stay ON dieselgg Whirlpool 7 January 2nd, 2010 01:38 PM
Frigidaire oven won't light problem christopher1963 Frigidaire/Tappan/Electrolux 25 July 2nd, 2008 08:40 AM
frigidaire oven takes long time to bake swammer Frigidaire/Tappan/Electrolux 9 November 30th, 2007 04:01 PM
Frigidaire Single Wall Oven Model# FEB30S7DCB, went blank msarbpd Frigidaire/Tappan/Electrolux 4 November 28th, 2007 11:34 AM
Frigidaire Gas Oven Will Not Light in Bake Mode bobkluck Frigidaire/Tappan/Electrolux 1 July 26th, 2007 12:07 AM
