Old December 28th, 2008, 02:25 PM
Capt Ike is on a distinguished road
Default Frigidaire Door Trim
I ran the self-cleaning cycle on this stove the other day and after it was done (reaching just under thermo-nuclear temperature) I noticed that the plastic trim piece on the door just behind the handle had turned a slight shade of yellow. Then about two days later two of the thin plastic pieces on the trim broke off. I think I found the part at RepairClinic (1197355), but it looks slightly different than mine. Can someone tell me if this is indeed the correct part for my model stove and also if someone has a link to the manual that shows how to remove this piece that would be fantastic! Thanks so much!
Frigidaire Range
Model FEFL74ASA
Serial VF14228648
Old December 28th, 2008, 04:34 PM
TechnicianBrian's Avatar
That door trim looks like the correct one to me. It is easy to replace by removing the door and placing it face down on a blanket. There are two screws in the upper corners that go all the way through to the handle. Remove each one, and replace the trim, then put it all back together.
TechnicianBrian
AllTechAppliance.com
Please help with Frigidaire model numbers Bruce Humphrey Frigidaire/Electrolux 1 November 29th, 2007 04:25 PM
Black grease smudges on clothes - Frigidaire LEQ332DS0 dixieagle Frigidaire/Electrolux 1 July 23rd, 2007 12:37 PM
Frigidaire Double Wall Oven or Repair Existing GE Wall Unit knittermom Frigidaire Brands Forum 5 February 8th, 2007 09:39 AM
Wiring for my new Frigidaire mgoogs Frigidaire/Tappan/Electrolux 5 December 7th, 2006 03:50 AM
Frigidaire Washer stackable with Kenmore Dryer?? hawai Frigidaire/Electrolux 1 November 22nd, 2005 01:53 PM
