Old February 10th, 2009, 03:39 AM
theodo155 is on a distinguished road
Default frigidaire crown series oven problem
I have a Frigidaire crown series Range model F04c367, serial #VF4470250 that has a oven problem. The lower element is no longer working. Just happened out of the blue. The top element is still working and heats up, just not the bottom. There are no error codes on the led display. Quite frankly I have never worked on an oven before and have no idea where to start. I did try wiggling the lower element but it didn't help.
Got any ideas?
Old February 10th, 2009, 09:25 AM
Yes, You'll need a ohm meter to check for continuity on your bake element. Make sure your home breaker is off to your oven first before testing it.
You can get a cheap volt/ohm meter at Radio Shack.
You can get access to the bake element from the back of your oven, by pulling it out away from the wall, or there should be 2 screws that hold it in from inside your oven, then you can usually pull the element out from inside your oven with the 2 wires connected to it.
Remove the wires and use the volt/ohm meter on the ohms setting and see what it reads, a good element should read 10-30 ohms.
Here's the bake element for your model:
Manufacturer's Number: 316075104
Frigidaire oven won't light problem christopher1963 Frigidaire/Tappan/Electrolux 25 July 2nd, 2008 08:40 AM
Frigidaire Crown Series FDEB23RGS2 Dryer Won't Start KDYaker Frigidaire/Electrolux 7 May 31st, 2008 09:57 AM
Frigidaire Crown Series Squeeling CJ51974 Frigidaire/Electrolux 9 April 23rd, 2008 12:57 PM
Frigidaire Single Wall Oven Model# FEB30S7DCB, went blank msarbpd Frigidaire/Tappan/Electrolux 4 November 28th, 2007 11:34 AM
Frigidaire Gallery series oven quit. danwa Frigidaire/Tappan/Electrolux 1 September 7th, 2007 11:20 AM
