Old July 2nd, 2009, 06:21 AM
theodo155 is on a distinguished road
Default Range losing power
I have a Frigidaire crown series Range model F04c367, serial #VF4470250 that has a oven problem. In the past year or so when we self clean the oven everything works fine except the clock display goes out and the oven will not unlock. I have found that if I just unplug the range and come back say 20 minutes later and plug the range back in it works fine (can bake or broil) until the next time I do the self clean operation. Then you must unplug again. Well about 3 days ago after using the oven the display went out after baking. Unplugging and plugging back in worked for about 20 minutes then the display went dead again. It now will come back on if I unplug and plug back in, but only for a little while then goes blank again.
Any Ideas?
Pete
Old July 2nd, 2009, 09:28 AM
Hi Pete,
You will need a new clock control board, but I need the full model# of your range, as they make a couple different ones for this model.
The model# tag should be located either inside the oven door, or on the very bottom frame in the front.
Old July 2nd, 2009, 10:10 AM
model # F04C367BSA
Serial # VF44702520
Old July 2nd, 2009, 04:02 PM
Manufacturer's Number: 5303935107
icon
icon
icon5303935107
Gas vs. Electric Range? Here is one more view... bobl Maytag/Magic Chef/Admiral/Jenn-Air 2 September 9th, 2008 04:00 PM
Kenmore 911.95281891 Burners/Oven Don't Work - Clock/Lights Ok - Power Loss Paul79UF Sears Kenmore 3 March 6th, 2008 10:35 AM
Whirlpool Electric Range shorted out half my apartment and now does not heat Gargy30 Whirlpool 1 July 29th, 2007 09:57 AM
Kenmore Range Power Shot Kyle Sears Kenmore 2 June 26th, 2007 07:53 AM
Frigidaire Range - Ongoing problems with EOC (electric Oven Contoller) filterthespam Frigidaire/Tappan/Electrolux 1 February 22nd, 2007 11:32 PM
