Old November 11th, 2009, 05:47 AM
olympic is on a distinguished road
Default Wall Oven will not heat
Hello,
I am trying to repair a Frigidaire wall oven for a few days now and I was hoping you might be able to point me in the righ direction. Model# GLEB27S7CBB. The elements will not heat up whether on broil, convection or bake. I replaced the clock/control module with the same results. The unit is about 5 years old.
Thanks for any assistance you can provide.
Old November 11th, 2009, 08:24 AM
Its possible your thermal fuse in the back of your oven is blown. You would need to turn the breaker off to your oven, then get someone to help you pull it out from the wall, then take off the back access panel and ohm out that thermal fuse for continuity with a ohm meter, you can get a cheap volt/ohm meter at Radio Shack.
Here's the location of your thermal fuse in the back of your oven, its #119 here:
http://c.searspartsdirect.com/lis_pn...8081-00002.png
Here's the thermal fuse for your model:
Manufacturer part#318004900 is RepairClinic item#499302
Its currently out of stock at RepairClinic, but in stock here:
Manufacturer's Number: 318004900 - Thermal fuse switch
Old November 14th, 2009, 05:47 AM
Unhappy
Thnaks for the recommendation. I swapped the thermal fuse with another one with the same results. I hear a clicking sound every few minutes but the temp stays at 100 F and there is no heat. There are 3 relays next to the panel could one of them be bad? I a looking at a new oven at this time?
Old November 14th, 2009, 01:09 PM
You really would need a volt/ohm meter to test voltage from the clock/oven control board.
9 times out of 10 the problem is either the clock/oven control board:
Manufacturer part number 318010700 is RepairClinic item number 499452
OR
the thermal fuse switch.
That other relay near the clock/oven control board is just for the convection fan motor and light.
I always first test for 240 volts were the power comes in to the terminal block, I've seen instances where I was only getting 120 volts across the 2 outer terminals on the power terminal block, that would cause it to not heat at all either. That would be a breaker/wiring problem to the oven in your home.
If everything checks good, then its likely a more technical underlying problem which would require a Frigidaire tech. to come out to see whats going on.
So if you plan on using this for the upcoming holidays then you may be safer to go with a new oven, unless you can have a tech. come out very quickly and order the part it needs quickly and hope it solves it.
KitchenAid KEMC378 Wall Oven "Close Door" Error Stover23 KitchenAid 3 November 9th, 2009 08:54 PM
Whirlpool electric in wall oven will not heat bullittandy Whirlpool 7 February 27th, 2009 06:57 PM
Frigidaire Single Wall Oven Model# FEB30S7DCB, went blank msarbpd Frigidaire/Tappan/Electrolux 4 November 28th, 2007 11:34 AM
Jenn-air wall oven doesn't close & temperature is off laroc Maytag/Magic Chef/Admiral/Jenn-Air 3 April 2nd, 2007 09:14 AM
Magic Chef Gas Wall Oven won't heat mndzab Maytag/Magic Chef/Admiral/Jenn-Air 1 January 23rd, 2006 10:49 PM
