Old December 14th, 2006, 06:38 PM
bairdind is on a distinguished road
Default Tappan Range Oven Problem
I am working on a Tappan Model TGF363AUA oven.
The oven comes on and pre-heats OK but when you open the oven door, the control panel loses all power. When you shut the door, the panel comes back on with the 12:00 blinking which indicates it lost all power.
Any ideas would be appreciated.
Old December 14th, 2006, 07:56 PM
#13 is the metal rod and #12 is the oven light switch in this parts diagram:
http://www3.sears.com/imaging/ImageP...&titleID=00003
Something may be shorting in the back where that light switch is, because when you open and close the oven door that rod moves back and forth to activate the light switch. Just pull the range out from the wall and open the back access panel and check that light switch or other wires for a short.
Old December 14th, 2006, 08:09 PM
I've been looking at a wiring diagram for that model but what I need is a schematic and I don't have one. It sounds like maybe the door switch might have something to do with the open circuit. Did this just show up and start all of a sudden? Is the 3 prong plug using a 2 prong addapter? If so is it pluged in the wall correctly? On the bottom of the control board is a row of wires. Make sure none are loose. In the mean time I'll keep looking for a schematic. Wish I was more help.
Rick
Old December 14th, 2006, 08:15 PM
Jake and I must have been replying at the same time. That sounds right Jake. Your the man!
Rick
Old December 14th, 2006, 08:30 PM
Yup, we were both replying at once, thats happened a few times with Jeff before too.
Old December 15th, 2006, 04:54 AM
Smile Great Help
Thanks for the information. I'll pull the back today and see what I find.
Old December 15th, 2006, 09:38 AM
Sounds good, keep us posted.
Old December 26th, 2006, 06:28 AM
Default Range Fix
The fix on this one was actually very easy. The symptoms didn't make sense as it would have taken a short on the door switch to kill the power to the control panel which should have tripped a breaker or gotten something hot. When I pulled out the range, I could hear a clicking sound in the panel and when I shook the power cord, it would do the same thing. After further checking, the outlet serving the range (about 20 years old) was bad.
Replaced the outlet and problem fixed.
Thanks for all the help though and this proves that we should look for the obvious first.......
Bob
Old December 26th, 2006, 08:56 PM
Glad that outlet was all that was wrong Bob.
Maytag MER5875QAS Range Post Self-Clean Oven Problem Lubes Maytag/Magic Chef/Admiral/Jenn-Air 7 June 10th, 2007 05:43 PM
Frigidaire Range - Ongoing problems with EOC (electric Oven Contoller) filterthespam Frigidaire/Tappan/Electrolux 1 February 22nd, 2007 11:32 PM
Kenmore electric range -oven problem Rob in Barrie Sears Kenmore 1 February 9th, 2007 11:04 AM
oven problem with caloric range jgarai Amana 5 December 20th, 2006 10:44 PM
Kenmore Select Clean Range Oven Problem jsebski Sears Kenmore 5 February 6th, 2006 07:14 PM
