I have read a few other threads, but I think this one is unique. I start the self clean cycle, (I removed the back panel) and watched the limit switch get made for the door lock. Then a about 30 seconds into the cycle, it bails out! The door unlocks and F9 comes up. I open the door and there is definately heat there. I don't know if is a watchdog thing or a temp. probe?
F9 is not listed in your codes. Model CFEF372BC2 Serial NF40419563 Any ideas. Thankls in advance!! Buggy |
Since this is a Canadian model, we have no information on your range.
You can message jeff1 here, he may know, he lives and has a appliance repair shop in Canada. Jake
I had the exact same thing happen. I found a latch about 3/4 to 1 inch long which sticks out from the top of the oven (facing towards you when you look at the oven) which is shaped like an L. If you open the oven door, look at the metal plate at the top of the oven (not inside the oven but on the piece which faces towards you at the top). The L shaped piece was turned to the side (about the 11 o'clock angle). When I turned the metal L piece so that it faced upwards (so that the L piece was faced towards 12 o'clock), then it corrected the problem. Good luck.
Sharon H |
I was searching for a way to fix the F9 error and found this thread, I tried what Sharon H suggested and bingo! it worked. Just turn the L shaped metal piece ever so slightly and then the beeping will stop and you're good to go. I'm glad I found this thread or else I would be up the creek. Thanks so much!
| self cleaning doesn't work on my kenmore built-in oven | gerg36000 | Sears Kenmore | 2 | May 8th, 2007 11:24 AM |
| Frigidaire oven model PLEFZ398ECB -- can't get the oven door back on | dbartlett | Frigidaire/Tappan/Electrolux | 1 | March 20th, 2007 11:43 PM |
| MayTag Oven; displays OFF after oven cleaning? | Hansaplast | Maytag/Magic Chef/Admiral/Jenn-Air | 3 | February 25th, 2007 05:10 PM |
| Frigidaire Double Wall Oven or Repair Existing GE Wall Unit | knittermom | Frigidaire Brands Forum | 5 | February 8th, 2007 09:39 AM |
| Frigidaire Oven or Thermador or ??? | Hawaii Bob | Frigidaire Brands Forum | 1 | January 17th, 2006 11:40 PM |
