Old May 12th, 2007, 09:20 PM
marvel06me is on a distinguished road
Unhappy Tappan model- door cannot not close
Tappan gas oven- TGF355
The oven door release is stuck and will not push back to receive door.
I tried to use the self cleaning function and not sure if it worked. After several hours, the oven was cold and tried to open door, but would not open. The bake/broil functions wouldn't work. So I unplugged and re-plugged- the functions work and I open the door with some manuever, but now it will not latch.
Is the automated door release broken? Is there a manual release? If so, where, how do I access this? Should unplug the stove for a long period to see if it resets.Can I repaired this?
I appreciate your help.
Old May 14th, 2007, 12:35 PM
There should be 3 or 4 more letters after the 355 in your model#.
Some models have the door release in the very back, you would pull your range/oven out from the wall and take off the back access panel and you would see it. Unplug your range first.
Kenmore model 790.9661* oven door problem hammesd Sears Kenmore 13 October 26th, 2008 09:18 AM
Jenn-air wall oven doesn't close & temperature is off laroc Maytag/Magic Chef/Admiral/Jenn-Air 3 April 2nd, 2007 09:14 AM
Tappan model# ACE Frigidaire/Tappan/Electrolux 1 April 1st, 2006 09:01 AM
Kenmore Dryer Model 11097588210 Kate Sears Kenmore 1 December 11th, 2005 12:32 PM
Model 110 44832202 emorabito Sears Kenmore 4 September 18th, 2005 11:55 AM
