Go Back   ApplianceBlog.com - Appliance Repair Forums > Appliance Repair Talk > Garbage Disposals
Garbage Disposals Garbage Disposal Problems?
Old April 13th, 2008, 10:11 AM
jamieg72 is on a distinguished road
Question ISE 1/2 hp stopped working
Yesterday I flipped the switch on the garbage disposal and it made a few loud grinding noises and then nothing. Now when I flip the switch, nothing happens at all - no noise. I found a button on the bottom of the unit and pushed it. Then when I flipped the switch it started to grind for a few seconds but then silence again. Nothing I do forces it to grind and now the water in that sink is barely going down. How do I get it going again?
Old April 13th, 2008, 11:41 AM
Sounds like something may be stuck in your garbage disposal grinder, Unplug your disposal then put your hand down in it and feel for something that may be clogging it, becareful if broken glass may be in it.
Old June 28th, 2008, 10:28 AM
reset button underneath, UNPLUG unit, get broom handle or similar wooden stick, insert into disposal, lean stick to one side and push back and forth until impellers/disposal spins. if it's not seized up this should get it loose- check for big debris pieces in disposal before plugging in and testing
Series 80 just stopped working, completely? daggerNC Sears Kenmore 8 April 8th, 2008 08:33 PM
Superba Convection Oven stopped working royriggs KitchenAid 6 October 16th, 2007 10:16 PM
Dispenser stopped working ice & water - Whirpool Gold ultimatehometeam Whirlpool 2 August 8th, 2007 11:47 AM
Superba Ice Maker stopped working. I think I know problem but need confirmation rockjeep44 KitchenAid 10 June 28th, 2007 11:01 AM
Kenmore Elite Microhood stopped working while cooking... Kiersten Sears Kenmore 3 July 17th, 2006 04:14 AM
