January 6th, 2013, 08:51 AM
Jammed Insinkerator 555SS
-major brand-
Hi:
I have an Insinkerator and I jammed it up by putting in leftover cooked chicken (large pieces). Later (everything appeared to be ok), I put in 4 large lettuce leaves. The garbage disposal was backing up and making a "sludge" which was incredible. It looks like the chicken became totally pulverized (like soft putty) and there were specks of green in it (lettuce). The little parts that grind up the food seem to be ok when I reach down (in that gunk) and the other side (double sink) is fine. We have had no problems until now, and I know that it is because of how I jammed it. Is there anything we can do? Is there a reset button on this particular model? There is a little "wrench?" that fits into a slot at the bottom, and my husband can turn that but nothing helps.
I can visualize that the pipe is covered with this sludge material.
Thanks for your help, suggestions.
Phyl
January 6th, 2013, 07:46 PM
Ok Phyl, most garbage disposals do have a little reset button on the bottom next to that little wrench, get a flashlight and try to locate it and push the button in and see if that resets it.
January 6th, 2013, 08:02 PM
Unfortunately, the little red button didn't re-set. I used that special wrench and it turns freely. Then I tried baking soda and vinegar but that doesn't work either. I am beginning to think that it is not the disposal but the drain pipe. Is it worth having a repair man look at it, or should I just get a new Insinkerator. Thanks, Jake.
Phyl
January 7th, 2013, 12:31 AM
It should come on then, if there is power to it. I'd just buy a new garbage disposal then.
By Fl_Gulfer in forum Whirlpool/Roper/Estate
Last Post: March 11th, 2011, 10:11 PM
By elizapt in forum KitchenAid
Last Post: March 14th, 2010, 10:52 AM
By cvthorn in forum Sears Kenmore
Last Post: December 17th, 2009, 11:20 PM
By bhuether in forum Garbage Disposals
Last Post: September 21st, 2009, 07:33 AM
By hopemick in forum Sears Kenmore
Last Post: June 8th, 2007, 12:00 AM
