Go Back   ApplianceBlog.com - Appliance Repair Forums > Appliance Repair Talk > Microwaves > GE/Hotpoint
Old August 6th, 2007, 09:25 PM
riverfour is on a distinguished road
Question GE Spacemaker JVM1630WB stop pressed still running
We have a GE Spacemaker JVM1630WB manufactured in 2001. It started giving trouble several months back, and we had to stop using it.
First, we had to open/close the doors many times to really stop it, otherwise, even pressed the "Stop/Clear" button, it wouldn't stop. When door was open, the machine was still running without heating (light and fan on). We need to open/close several times to really shut down. Finally, even we tried many times to open/close door, it wouldn't shut itself down. So we gave up and stopped using it.
Today, I followed online instructions to detach the control panel assembly and tested the 2 door switches (N.O. Normally Open) and 1 door switch monitor (N.C. Normally Closed) with Ohmmeter. They are all OK. I also cleaned their terminals with sandpaper. Then I put the control panel assembly back and confirmed the switches are depressed when micorwave door is closed. I confirmed it by both listening the clicks and observed switch depressed with flashlight. After that, I tested microwave, it seemed that the door switches are working well. Everytime, I opened the door the machine shut down itself completedly. However, when I pressed "Stop/Clear" button, the machine still wouldn't shut itself down, and it is running with light and fan, but not heating. I have to open the door to shut itself.
I would conclude that the door switches are functioning well (please correct me if I am wrong, and give explanation). I suspect the control circuit is bad, which is costly. I might need to go for a new machine for a different brand.
Any suggestion is welcome before I totally give up on this GE unit.
Thank you very much,
Maytag Fridge WONT STOP RUNNING sheepdog Maytag/Magic Chef/Admiral/Jenn-Air 1 June 22nd, 2007 02:27 PM
How can I stop this fridge from running!!!??? brad123 Maytag/Magic Chef/Admiral/Jenn-Air 6 August 29th, 2006 01:17 PM
Maytag Dryer won't stop running. mrstree Maytag/Magic Chef/Admiral/Jenn-Air 6 June 28th, 2006 09:20 PM
Kenmore Electric Dryer Won't Stop Running WadeB Sears Kenmore 2 December 7th, 2005 06:46 PM
KitchenAid Dryer wont stop running arrow_choi Whirlpool/KitchenAid 1 August 22nd, 2005 10:18 PM
