Hello all,
I have a problem with my GE gas dryer of about 7years old. When the dial is turned to start all you hear is a humming sound coming from inside the casing. I have looked at other forums and have taken the dryer apart. I have the drum, belt, and case all over my laundry room. I have gone through and cleaned all of the dust and lint I could get and still have the same problem. I haven't put everything back together and tried starting it to get the same humming and no movement on the pulley and belt. Does this sound like a bad motor and if so is it difficult to replace having never opened a dryer before? Also is the repair cost worth it? I havent heard a lot of good things online regarding older GE dryers. Will I end up with the same problem 3 years from now if I replace it? If I have someone come to fix the problem am I better off buying a new dryer for the cost? Any help or ideas would be greatly appreciated. Thanks, Scott |
Whats the model# of your dryer? its located either inside the door or on the top console. Sounds like your motor is bad, if you use your dryer daily/many times a day, after 7 years its better to invest the repair money into a new dryer, as other parts are wearing as well. Jake
The model number is DPSR473GW1WW. If it is the motor you are probably right with purchasing a new one instead of fixing this one. I just have to convince my wife of that, ha ha. It gets used now that we have kids probably on average of at least one or two loads a day. Thanks, Scott |
Thanks Scott,
Here is the parts diagram for your model: DPSR473GW1WW Diagram#5 part location#630 is your motor assembly. Here are some help links in case you decide to take it apart: http://www.applianceaid.com/ge-dryers.html http://www.applianceaid.com/take-apart.html http://www.applianceaid.com/gemotor.html Jake
Well I found almost the identical dryer (newer model) at Home Depot on sale. I think with a current sale and a 10% discount card I have I can get it for just under $350. I think it will probably be worth the extra $200 to get a new one instead of trying to change out the motor.
Thanks for the help, Scott |
Ok, sounds good Scott.
| GE gas dryer, humming. | don32 | GE/Hotpoint | 1 | October 1st, 2006 04:09 AM |
| GE dryer (DDG8080MALWH) - humming noise | ltmathew | GE/Hotpoint | 1 | December 11th, 2005 12:01 PM |
| Whirlpool Dryer gets Warm not Hot, Takes long to Dry | jnicosia | Whirlpool/KitchenAid | 4 | August 19th, 2005 08:48 PM |
| Kenmore dryer making humming noise | bt0q | Sears Kenmore | 3 | July 13th, 2005 07:16 PM |
| Kenmore 90 Series Gas Dryer Problem | HomeRepairGreenhorn | Sears Kenmore | 9 | March 15th, 2005 01:02 PM |
