Old September 8th, 2007, 12:40 PM
gabohr is on a distinguished road
Default I just want to open the oven door!!!!!BEFORE HUBBY GETS HOME!!!
Please!!!! I need help!!! Basically, I forced the oven latch to the right and now it won't return all the way to the left. I tried everything I could think of and if the latch assembly wasn't broken before, it is now. I just want to release the latch to open the door--- BEFORE MY HUSBAND GETS HOME AND HAS A FIT!!!!! It's a GE JBP26GK Electric
Old September 8th, 2007, 08:27 PM
Hi gabohr,
Try moving the lever back to the right as far as it will go. Find something to wedge between the lever and the opening on the left side to keep it from moving, then bend it back to the left.
Rick
Old September 9th, 2007, 04:43 PM
Default Jammed latch lever...
Hi Rick,
I tried your suggestion... I put a wedge between the lever and the opening on the left side to keep it from moving, then bent it back to the left. Unfortunately, it didn't work. I think I must have completely destroyed the assembly. Is it possible to open up the stove top to access it??
Old September 9th, 2007, 06:58 PM
Hi gabohr,
You're not going to like this, there are two screws, one on each side of the latch lever. Take them out first. Take the back off of the range and you'll see a solenoid attached to a double set of rails that extend forward to the latch assembly. The solenoid, rails, and latch assy come out the back as a unit. Be sure to mark your wires so you put them back in the right place.
Rick
Old September 10th, 2007, 10:58 AM
Default Jammed Latch...
Ok...Rick,
I can do this. I do have a question though. I hope this doesn't sound too stupid... but how do I get to the two screws on either side of the latch lever if the oven door is locked and in front of them?? I do remember seeing screws there when the door was open and I was cleaning up a bit.
Kitchenaid Thermal-Convection Oven won't open coopers KitchenAid 2 May 18th, 2007 10:17 AM
Jenn-air wall oven doesn't close & temperature is off laroc Maytag/Magic Chef/Admiral/Jenn-Air 3 April 2nd, 2007 09:14 AM
Electric Super Capacity 465 - Oven LED "LOC" (Oven door will open but won't heat) marcum03 Whirlpool 1 September 29th, 2006 09:41 AM
Oven door wont open Humber Hull Maytag/Magic Chef/Admiral/Jenn-Air 1 September 19th, 2006 04:52 PM
