Results 1 to 4 of 4
Thread: My Dryer takes forever to dry clothes
    timbotide is offline Member
    Sep 2007
    Alabama
    Unhappy My Dryer takes forever to dry clothes
    My GE Profile Dryer Model# DPSF495EW0WW takes way too long to dry a load of clothes. Sometimes over 2 hours for a large load.
    The vent pipe is clear and the lint filter is clean.
    When I set the dryer to "Timed Dry" the element pulls 11.5 amps for 1.5 minutes and then turns off for approximately 45 seconds before coming back on. The element does not looked shorted or burned in any way.
    Can someone tell me what could be happening to cause this problem?
    I sure hate to go out and buy a new one when something simple could
    fix it. Thanks.
    Tim
    Sep 2007
    Alabama
    I just unhooked my vent hose and the air temp was 130 degrees while running in Auto Mode and Timed Mode as well. I have a small load in the dryer and it took over an hour for then to dry.
    Sep 2007
    Alabama
    I finally decided to remove the drum and expose the heating element.
    There was a break in the element coil on the side where the two power wires connect
    to the element.
    Sorry for the delay, its been very busy.
    Glad you found the problem was the heating element.
    Here's the one for your model, in case others need to order it as well:
    Manufacturer part#WE11M23 is RepairClinic item#844418
  1. Dryer does not heat up to dry clothes
    By pango in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 6th, 2007, 05:06 AM
  2. Dryer burner wont stay on long enough to dry clothes
    By billyboy in forum GE/Hotpoint
    Last Post: October 5th, 2006, 10:13 PM
  3. Replies: 5
    Last Post: September 22nd, 2006, 09:48 PM
  4. Kenmore dryer takes hours to dry cloths
    By fritcr in forum Sears Kenmore
    Last Post: September 1st, 2005, 08:17 AM
  5. Whirlpool Dryer gets Warm not Hot, Takes long to Dry
    Last Post: August 19th, 2005, 09:48 PM
