I have a 10-year old GE Potscrubber and have a question about how the seals are supposed to work. I currently have a problem where I get leaking during the wash cycle and I can deduce that the suds are pushing up and over the lip of interior tray (bottom of washer) and the dripping onto the floor.
When I pull the inside panel off of the door, I see that the gasket runs nicely all around the top and sides, but it does not meet up at the bottom. In fact, there's about a 3-4 inch segment with no gasket - is this normal? So, I started thinking that we must just be using too much soap which is causing excess sudsing which is coming through between the bottom tray and this gap in the gasket. But I don't think we're using any more soap than previously. I can imagine some shrinkage of the gasket over the years, but this would be ridiculous.... Any thoughts? Thanks, Ken |
Hi Ken,
Up here in Oregon, the water is very soft, i see this happen alot. The softer the water, the more chance of suds. Thats the odd part, my customers will say they have been using the same amount for years, and everything was fine. I don't know why all of a sudden it starts doing it. But after they use less, it works fine. I explain to my customers to use half of what your using in detergent. The door gasket gaps at the bottom are normal. Jake
Hi all,
This just pushes into place.... Gasket insertDO use less soap as Jake suggested. jeff.
Guys,
Thanks for the responses. We'll be trying less detergent. I'm weighing the option of buying the 4" insert gasket (the shipping's almost more than the item). I think we'll try the detergent change first. Thanks, Ken |
| need Tub Seal for Kenmore 417.41042000 Washer | Adelescomp | Sears Kenmore | 1 | May 21st, 2007 10:34 AM |
| Kenmore 417.29042991 Need Seal For Bearings | CJR | Sears Kenmore | 3 | March 20th, 2007 01:48 PM |
| Seal lubrication on reassembly. | gregj | KitchenAid | 10 | June 19th, 2006 10:57 PM |
| Door seal on Kenmore S/S | b green | Sears Kenmore | 9 | February 19th, 2006 12:22 PM |
| Kitchenaid DW motor housing seal | brubro | KitchenAid | 9 | November 14th, 2005 08:40 AM |
