Old October 23rd, 2007, 10:27 PM
danhustonii is on a distinguished road
Default GE Triton Model #EDW4000G03WW won't drain
Greetings All:
I have a GE Triton Model #EDW4000G03WW and it is not draining. I have read many posts and I am not sure which type of model this one is as far as what I should check next.
I have checked the drain hose to the garbage disposal and it is clear. I checked the sump entrance screen and there was some stuff there from the water but just small food particles. I took it off anyways and sucked all of the water out. I also sucked all of the water out of the drain hose. I then put some clean water in the sump and sucked it back out through the drain hose.
So it sounds like this plunger thing but this model does not seem to have a self cleaning option so I am a little confused. Can someone point me in the right direction?
Dan
Old October 24th, 2007, 10:35 AM
Does your drain pump make any kind of noise at all when it trys to drain?
GE super capacity plus Model S4200B2WW won't drain phongeer GE/Hotpoint 7 September 16th, 2007 10:08 PM
Whirlpool Model LSR7233EQ0 won't drain during spin cycle emartin5 Whirlpool/KitchenAid 2 June 29th, 2007 12:03 PM
Whirlpool Model # LA6800XM does not drain phxtim Whirlpool/KitchenAid 1 August 8th, 2006 07:58 AM
Model 110.29962(891) drain problem. Tigger#76 Sears Kenmore 9 June 11th, 2006 03:19 PM
ge triton III won't drain dvg GE/Hotpoint 3 June 7th, 2006 11:21 AM
