Old November 9th, 2007, 08:28 PM
wolter is on a distinguished road
Default WCSE4230A0WW won't complete agitate cycle
I've got a GE WCSE4230A0WW top load washer from 2002. The washer currently will start the wash cycle (in cotton and permanent press mode), but several minutes in, the motor will start clicking and cycle on/off (at least that is the appearance). It does this behavior whether the wash speed is set to normal or gentle. If I run the quick rinse cycle, it will go through (most of the time) and finish normally. Does this sound like a clutch problem or some electronic controller problem?
Thanks for any assistance
Old November 9th, 2007, 08:58 PM
I forgot to mention that I ran through the field code test for the washer and it showed the same clicking behavior when selecting the slow agitation test. The fast agitation test seemed to work fine as did the drain and spin tests.
Old November 10th, 2007, 02:06 PM
WCSE4230A0WW
Diagram#2 Part location#630 is your motor/clutch assembly, thats likely the problem, I've replaced many of these for the same issue.
If you purchase parts from our links here and you install them and it doesn't fix the problem, you have a 30 day full refund.
Quiet Partner DU915PWK does not complete cycle ga_freckles Whirlpool 8 August 3rd, 2007 10:04 AM
Bosch dishwasher does not complete cycle rck46 Bosch 1 July 18th, 2007 11:14 AM
shu5312uc will not complete cycle -- water continuosly circulates rpattison Bosch 6 June 30th, 2007 09:14 PM
Shu4002UC will not complete cycle Giles Bosch 8 March 8th, 2007 09:18 AM
kenmore electric dryer stops before cycle is complete ragincajundad Sears Kenmore 8 November 4th, 2005 03:11 PM
