Old November 13th, 2007, 06:34 AM
Littlern is on a distinguished road
Default GE Factory substitute for WB27K5299
I ordered the part from repairclinic.com as shown on their and GE's web sites - WB27T10264 (844426). Can see it is not a drop-in-replacement for the WB27K5299 currently installed, not even close. Repairclinic.com says "will possibly need to be installed by an appliance repair person". Any guidance on changes necessary for the installation?
Old November 13th, 2007, 06:57 AM
By the way, this is for the control module for a GE wall oven model JKP15BW2BB.
Old November 13th, 2007, 04:43 PM
The WB27T10264 is the correct one for your model:
Manufacturer part#WB27T10264 is RepairClinic item#844426
It should of come with installation instructions, did yours?
Old November 14th, 2007, 09:24 AM
All that came with it was a fuzzy page of line drawings of the supposed old and new controls - no explanation of wiring changes, no pinouts, and the line drawings do not resemble anything in the box.
Old November 14th, 2007, 10:56 AM
Ok, then you will definitely need an appliance tech. to come install this for you.
Old November 20th, 2007, 06:41 AM
I initially expected the button contacts on the control to line up with the corresponding points on faceplate touch panel. Once I opened the oven up and removed the failed control it was pretty obvious I was incorrect, and just as obvious how to do the swap. Installed it last night, working well. Don't know what the instructions included were for, but not for the control they came with. The drawings included with the new control had the same connection names, but the layout of the connections and the circuit boards were nothing like those of the new control. I think GE's supplier screwed up. Thanks for your assistance.
Old November 20th, 2007, 10:34 AM
Sounds good, glad you got it installed ok.
Frigidaire Upright Freezer (20 cu ft) Model LFFU2067DS factory service manual signgoddess Frigidaire/Electrolux 1 August 19th, 2007 08:07 PM
Amana/Maytag Refrigerator Model SQD23VW Factory Service manual signgoddess Amana 1 August 18th, 2007 11:44 PM
I got screwed by A & E factory repair service screwed user Frigidaire Brands Forum 1 September 1st, 2006 08:15 AM
