Old November 21st, 2007, 02:16 PM
Bill_O is on a distinguished road
Smile GE GSD2230Z04WW heated dry switch
My dishwasher recently died in the middle of a cycle and would not drain. After manually emptying the machine I tried another cycle and it would not add water. Checking I found that the heated dry switch was defective. The switch is a rocker on-none-on type and neither contact was making a circuit. I found a replacement (hope this is allowed on the blog) at Allied Electronics 800-433-5700. The manufacture part # is RSC143D1100 and the Allied part # is 683-0115. Swapped out the switch and it works like new.
I noted in an early thread that a Bill from VA had a similiar problem with the heated dry switch and GE tried to tell him that a switch with only two contacts would work. Bill I hope you solved your problem but if not the above switch is a good fix.
Old November 21st, 2007, 04:01 PM
Good job Bill.
But for those who want the original here's the parts diagram for this model:
GSD2230Z04WW
Diagram#3 Part location#905 is the heated dry switch kit.
Maytag MDB7100AWW flashes 'Heated Dry' mikeg1025 Maytag/Magic Chef/Admiral/Jenn-Air 0 August 4th, 2007 11:09 AM
Whirlpool won't drain (not the lid switch). AndrewD Whirlpool/KitchenAid 3 June 7th, 2007 10:10 AM
Frigidaire model FSE748GFS1 cannot get to broken switch gordoncf_s Frigidaire/Electrolux 1 May 28th, 2007 01:53 PM
Kenmore 587.15142400 doesn't dry LeoK000 Sears Kenmore 1 April 1st, 2007 12:22 AM
Jenn Aire cooktop switch replacement dfleming Maytag/Magic Chef/Admiral/Jenn-Air 0 November 11th, 2006 10:54 AM
