Old November 27th, 2007, 03:29 PM
drayburn is on a distinguished road
Default GE washer transmission question
GE washing machine M# wvsr1060a1ww. I removed the agitator coupling to find out where a water leak was coming from. I then noticed that the splined shaft on the transmission moved back and forth, which to me indicates a bearing problem. Am I correct or is that movement OK?
Old November 27th, 2007, 05:17 PM
WVSR1060A1WW
Diagram#4 Part location#310 is the agitator coupling, is that what your referring to?
Old November 28th, 2007, 06:36 AM
appliancetec is on a distinguished road
Your right the shaft should not move side to side sounds like your going to have to replace the trans if you want to fix this machine..I serviced GE washers for a federal prison in my area and we replaced dozens of these transmissions . They arre not too expensive ,and not too hard to replace but if you do order the nut that holds the basket in ,its white metal and is hard to get out better to cut it with a chisel and replace it new. good luck...
Seal replacement on Kenmore washer transmission bobtx Sears Kenmore 1 August 25th, 2007 11:59 AM
washer transmission darkwing Amana 1 November 3rd, 2006 12:08 AM
Maytag LAT8826AAE washer - Transmission warranty? DaveS Maytag/Magic Chef/Admiral/Jenn-Air 3 July 19th, 2006 04:37 PM
Question on buying a new washer? Mbllight GE/Hotpoint 3 February 19th, 2006 06:54 PM
Washer transmission question sun45 Sears Kenmore 1 November 16th, 2005 10:57 PM
