Old November 28th, 2007, 09:27 AM
Carl H. is on a distinguished road
Default Gas oven wont turn off.
GE XL44 JGBS16WEP1WW
The oven will not turn off. It happened once a year ago and cleared itself, but now it stays on until the gas is shut off.
Last night I went to boil a pot of water. The oven had stuck on earlier in the day and I had the oven knob off and the gas turned off for about 4 hours. When I turned the gas back on the stove top burner worked just fine, but the oven turned on too, and the temp kept on rising past what my oven thermostat could register.
I just now tried it again and the oven will not turn off. I cut the gas, but the igniter is still glowing an hour later. What should I be looking at?
Thanks, Carl
Old November 28th, 2007, 01:52 PM
Replaced thermostat, all is good.
Old November 28th, 2007, 10:53 PM
Glad you found the problem and fixed it Carl.
Here's the oven thermostat for this model, in case others with this model need to order it as well:
Manufacturer's Number: WB20K8
Whirlpool Super Capacity 465 / Gas Oven jeff_465 Whirlpool 4 November 25th, 2007 12:26 AM
Kenmore gas oven slow to heat up t7044wa Sears Kenmore 5 November 6th, 2007 03:43 PM
Oven won't turn off rj123456 Ranges 2 October 7th, 2006 05:27 PM
Magic Chef Gas Oven - 3110KRW svwilly Maytag/Magic Chef/Admiral/Jenn-Air 3 September 29th, 2006 04:45 AM
Maytag Gas Oven - oven startup/popping problems kpd Maytag/Magic Chef/Admiral/Jenn-Air 1 April 11th, 2005 10:37 AM
