GE MODEL DNCD450EA0WC
Timer window shows 45 minutes of drytime at startup. After 3 to 4 minutes it goes into cooldown for 5 minutes and shutsdown. I have checked the unit for excessive lint which it didn't have. While I was in that far I replaced the thermistor and the thermastat switches post blower. The control panel board was replaced 1 year ago. any ideas? Thanks Jacksprat |
Since the original post I have decided to order all 3 of the temp limiting devices on the heating coil shroud. One of them is opening up prematurely. If this doesn't work my it needs repainting. Jacksprat
Might also want to check the connection at the control where the thermistor plugs in. A little corrosion can give you a false reading causing it to count down prematurely.
Let us know what you find. |
Thanks, I will check those connections today.
Well I found out what the problem was. After several teardowns and reassembles to test run the dryer, thinking that limit devices had failed, I just happen to notice a small wire that was welded to the heating coil on one end and to the heating coil shroud on the other end. It was an ordinary staple that had worked its way into the coil chamber and found a solid home. I removed the culprit and reassembled the dryer. It runs fine now. Thanks for your help though. JACKSPRAT |
| HE3t Elite won't STOP drying - lock-up at 7 min left? | rwillis@Pobox.com | Sears Kenmore | 4 | November 23rd, 2007 03:45 PM |
| Frigidaire Electric Dryer Only Stays Hot For 5-8 Min | Its Broke | Frigidaire/Electrolux | 5 | November 4th, 2007 10:37 PM |
| Kenmore: runs 3-10 min, heats, shuts off | Sduncanjd | Sears Kenmore | 5 | December 13th, 2006 11:41 AM |
| 665.15921690 Kenm. sticks @ about 45 min. | Humboldt | Sears Kenmore | 3 | November 12th, 2006 10:28 PM |
| Bottom freezer slow to cool, min temp 29 | JandJW.Vt | Amana | 1 | August 30th, 2005 02:25 PM |
