Old February 18th, 2008, 02:02 PM
orangeman is on a distinguished road
Default GE GJXRP080B0WW Top Loader, keeps adding water
MY GE top loading washing machines does the following....
- Water level fills up and stops ok
- After a pause, it begins agitate cycle ok BUT it wants to add more water at this point when the machine is already full so it would overflow. If I turn off the water supply, it will continue to agitate.
- After agitate cycle is done, it drains old water ok.
- After old water is drained it goes into its spin cycle ok.
- Halfway through spin cycle, it wants to add water... not ok. I have to tutn water supply off again.
- I manually advanced spin cycle a bit to get that bit of water to drain away which it did.
- It continues to spin, and spin and spin, even after getting to the very end of the wash cycle. It still spins. I have to open the lid to get it to stop.
Any ideas?
Thanks in advance.
Old February 18th, 2008, 02:24 PM
Bambiblaster's Avatar
I would have to say the timer is bad,,, Motor in timer stops advancing
Old February 18th, 2008, 03:50 PM
The timer, I assume that is the big switch that I just took out. The one that you set the wash cycle to and then pull the rotary dial out to start the machine?
I took it out with the intent on seeing how I could get a new one.
Old February 18th, 2008, 09:45 PM
Here's the parts diagram for your console assembly:
http://www.searspartsdirect.com/part...2065-00001.png
#100 is your timer.
Here's the timer for your model you can order:
Manufacturer's Number: WH12X10202
icon
icon
icon
Do you notice a difference in your water bill when switching from a top loader Kristinemomof3 Washers 3 March 20th, 2008 09:42 PM
Kenmore 80 series-skips adding rinse water?? Swanny Sears Kenmore 5 February 16th, 2007 10:41 PM
Kenmore 417 ~ Front Loader Washer ~ water problem washertrouble Sears Kenmore 5 January 3rd, 2007 08:48 PM
