Old May 2nd, 2008, 12:45 PM
jessie jo is on a distinguished road
Default no oven
Have a Hotpoint gas range with standing pilot,model no RGB508PPA2W,the oven will not light.If you turn oven control to 350 the standing pilot will flare up to try to light the burner,but there is no gas coming thru the burner,what controls the flow of gas to the burner?Is it the thermostat or the gas valve control or both of these? Does the thermostat tell the gas valve to open? How can I trouble shoot this range?
Old May 2nd, 2008, 05:53 PM
The thermostat tells the Safety Valve to open after the increased pilot gets the safety valve bulb sensor hot.
So your safety valve is bad and not opening to let the full gas for the oven burner through.
Here's the safety valve for your model you can order:
Manufacturer's Number: WB19K12
icon
icon
iconWB19K12
#214 is your safety valve here:
Its easy to access, just take the bottom of your oven off, then the burner shield, then you'll see the burner tube with the safety valve sensor bulb attached to it, remove that bulb and the metal wire that goes to your safety valve, then remove the safety valve itself, and install the new one the same way you took off the old one.
Old May 3rd, 2008, 01:52 AM
Default no oven
Thank you for your help.So I should replace the oven safety valve,I guess from reading what you said the thermostat is working.Thanks again for your time and know how.
Old May 3rd, 2008, 07:33 AM
Yes, that should fix it. I've replaced alot of oven safety valves in the last 20 years for this exact same issue.
Old May 3rd, 2008, 07:35 AM
Default no oven
Thank you ever so much.
Old May 3rd, 2008, 07:59 AM
Glad to help jessie jo.
kitchenaid oven - preheat and temp display problem BTraut KitchenAid 8 February 7th, 2008 06:16 PM
Frigidaire Single Wall Oven Model# FEB30S7DCB, went blank msarbpd Frigidaire/Tappan/Electrolux 4 November 28th, 2007 11:34 AM
Whirlpool Super Capacity 465 / Gas Oven jeff_465 Whirlpool 4 November 25th, 2007 12:26 AM
Thermador CT230 wall oven - blower starting by itself rlsmith Ranges 4 May 18th, 2007 09:23 AM
