Old June 5th, 2008, 07:43 AM
appliancecenter is on a distinguished road
Unhappy GE wall oven latch lock help
can anybody please advise?
i have a GE double oven model # JKP44G0P1BG and the upper oven door is open and the lock assy is closed and on the display it says LOCK how can i unlock the oven lock to be able to close the door properly
Old June 5th, 2008, 10:25 AM
You'll need to pull the oven out a little from the wall, then take off the console to get access to that lock/latch motor, its likely the switch on it is stuck.
Here's the lock/latch motor assembly for your model:
Manufacturer part#WB26K5030 is Repair Clinic item#253901
WB26K5030
Make sure the breaker to the oven is off first before you open the console.
Old June 5th, 2008, 10:47 AM
Default resolved !!
what i already figured out meanwhile is that i left the oven with self clean (to run a full clean cycle) and after the cycle finished and i cooled off it got unlocked
Old June 5th, 2008, 07:25 PM
Ok Sounds good, glad its ok now.
Frigidaire Single Wall Oven Model# FEB30S7DCB, went blank msarbpd Frigidaire/Tappan/Electrolux 4 November 28th, 2007 11:34 AM
Thermador CT230 wall oven - blower starting by itself rlsmith Ranges 4 May 18th, 2007 09:23 AM
Wall oven under cooktop renochick Ranges 1 April 30th, 2007 09:37 AM
Jenn-air wall oven doesn't close & temperature is off laroc Maytag/Magic Chef/Admiral/Jenn-Air 3 April 2nd, 2007 09:14 AM
Frigidaire Double Wall Oven or Repair Existing GE Wall Unit knittermom Frigidaire Brands Forum 5 February 8th, 2007 09:39 AM
