September 16th, 2005, 06:19 AM
GE Water Dispenser Line keeps freezing up ...
Hi!
I have a GE side-by-side refrigerator model TFX26KRDAWW.
The water line (located behind the dispenser) for the outside dispenser keeps freezing up! It started happening after the unit was about two years old.
When it first happened, I did the normal diagnostic checks of the refrigerator side reservoir, switch, etc. and finally diagnosed it as being the water line behind the dispenser that was frozen. In fact, the area where the water line rests was frozen solid.
I thawed it out and put the dispenser back together and it froze up again in less than a week. So, I thawed it out again and put some additional insulation in there and it lasted about six months before the water line froze yet again.
There is some kind of "heating" element on the back of the dispenser housing and it's a "little" warm to the touch. I was wondering how "warm" this should get and if the cause of the line freezing was this element failing.
I really don't know what else to do .... any ideas????
September 17th, 2005, 05:12 AM
A guess....how cold is the freezer temp?
Approx an 10-20 watt heater = not overly warm.
September 17th, 2005, 09:39 AM
Originally Posted by
jeff1
It's set in the middle of the temp range.
I went out a bought some new (thicker than original) insulation today and really packed it in there along with a vapor barrier between the freezer door styrofoam and the new insulation.
I have my fingers crossed ....
September 17th, 2005, 12:25 PM
Sorry....I meant acual temp in ºF or ºC.
That should help
October 10th, 2006, 06:15 AM
This is the exact same thing that is happening to me. I have a GSS22SGRE that started this about a week ago. It is also just over 2 years old. The freezer temp is around 0 degrees. I have thawed the line by opening the freezer door for about 15 minutes, but it re-freezes in a couple of days. I'd like to try the insulation thing Oxen72 tried, but don't know how to disassemble the dispenser. Other posts have said the front panel should snap off, but I don't want to break anything. Is there a repair manual or something that would give me more confidence?
February 4th, 2007, 05:36 PM
Same freeze up problem
I have a GE refrigerator going on 3 years old. Same problem. Same question as last post, what does it take to open this up? I can remove the front cover, but I don't get to the water line inside toward the back (close to the inside of the freezer).
Background: I've thawed with hair dryer, then I've thawed the entire door for hours (shoved insulating cover in the opening), both times a couple of days later the water line is frozen again.
Any help would be greatly appreciated.
February 5th, 2007, 07:52 AM
Try contacting GE customer service
I finally contacted GE last month, and so far they have been great working with me. It appears there's an insulation problem, and they are going to replace my door, but it is on backorder. I'll let you know the results.
February 20th, 2007, 06:50 PM
Thanks for the update
I'll contact them. I had read elsewhere about someone's horrible experience with GE customer service over this issue, so I wasn't really inclined to do so. I'm glad to hear they are aware of the problem - at least have admitted so in your case. I wouldn't really care about a backorder as long as they'll do something about it.
Do let me know what happens to you.
February 21st, 2007, 04:24 AM
Problem Solved
April 23rd, 2007, 11:45 AM
I'm glad I found this forum. I have the same problem with my GE side by side. After my own troubleshooting, I came to the conclusion that the water line to the dispenser was blocked somehow. After discovering this forum, I had to go no further on my own. I contacted GE customer service and set up an appointment with a tech. He arrived 2 days later and diagnosed the problem exactly as has been the case here. I did mention that I had read about this problem on this forum. The normal parts & labor charge for this problem would be $750.00. However, he said GE has been "concessioning" the freezer door in "many" cases. He scheduled a free delivery of a new door in one week. I only have to pay for the service call, ($90.00) and the labor to install the new door, ($165.00) Since I also have a rust stain traveling down the front of the door from the water dispenser anyway, I feel this is more than fair.
By jxp_app in forum Amana
Last Post: February 8th, 2007, 10:49 AM
By dlynch in forum GE/Hotpoint
Last Post: October 4th, 2006, 08:17 PM
By Schly in forum KitchenAid
Last Post: July 9th, 2006, 11:35 PM
By batman in forum Frigidaire/Electrolux
Last Post: June 13th, 2006, 11:15 AM
