Go Back   ApplianceBlog.com - Appliance Repair Forums > Appliance Repair Talk > Microwaves > GE/Hotpoint
Old June 27th, 2008, 05:17 PM
trips52 is on a distinguished road
Default ge advantium 120
ok just went to go microwave a cup of water and opened the door put water in, microwaved water. after it was done I oped door took water out closed door and the light stayed on and turntable turned........
and just keeps on going unless I turn off the power...... everthing still works fine it just stays on after it gets done microwaving.......
please help, it sucks having to go out in the garage turn the breaker off and on in order to use it
Old June 29th, 2008, 03:21 PM
ok here is some more info.... you turn the power on and the fan turns on and light, but its not microwaving. just fan,light and turntable. you press one of the buttons microwave, speedcook, oven, ect and they work fine. after you get done cooking you can press stop and it stops cooking but the light and fan stay on.
if you open the door during cooling it stops close the door and light and fan turn on again....
it doesn't seem like a door switch because you open it and it shuts off. also you can press stop or cancel, and it works fine. everthing works fine just light fan and trurntable stay on....
help....
Old June 29th, 2008, 07:29 PM
GE JIM is on a distinguished road
Trips...Sounds like you may have a problem with the control board..Possibly a stuck relay...You will need to post the complete model number and someone will get you a part number..
Old July 2nd, 2008, 06:42 PM
Trips...Got your msg..Model is sca1001kss...I'll get back to you tomorrow...Jim..
Old July 3rd, 2008, 09:37 AM
Here's the smart board assembly for your model you can order:
Manufacturer's Number: WB27X10776
icon
GE SxS GSS25SGMDBS compressor not running. iamhere77 GE/Hotpoint 19 June 3rd, 2008 05:55 PM
Advantium 120 Problems HELP! TimTucson GE/Hotpoint 0 July 7th, 2007 10:15 AM
ge advantium 120 trips52 GE/Hotpoint 3 January 26th, 2007 03:35 PM
ge advantium 120 oven trips52 GE/Hotpoint 0 January 22nd, 2007 03:52 PM
