Old July 6th, 2008, 08:06 PM
tomatkins is on a distinguished road
Default GE Triton GSD5500G03BB
Hi
I have a approx 3.5 year old GE Triton GSD5500G03BB dishwasher. Today, I saw the wash cycle continue for over an hour or two (with 2 sensor lights on the control panel lit green - WASHING and SANTIZED - ON at the same time when I looked at it). I could hear the water moving.
I pulled the lever that closes the front door, to the left to shut the cycle and open the door. There was hot water inside and the dishes were clean.
After 5 minutes, I closed the door, pulled the lever to the right. The machine started on again. This time the sensor lights on SIMULTANEOUSLY were - RINSING and SANTIZED. After a few minutes, it went back to WASHING and SANTIZED simultaneously. At this point, I shut off the cycle by pulling the door lever to the right.
I let it sit for a few hours and then opened the door again. There is about 2 inches of water sitting in the tub. This water has now been sitting there over 6-7 hours.
I cannot see any water leakage in front. The drain from the dishwasher goes into the garbage disposal. The water in the kitchen sink drains fine and the garbage disposal is working. I cannot see any leaks where the drain pipe from the dishwasher connects to the garbage dispoal either.
Can you advise on what the problem here is and how it can be fixed.
Tom
Old July 6th, 2008, 10:02 PM
Hi Tom,
Yes, you will need a new module control.
Manufacturer part#WD21X10240 is RepairClinic item#1174062
WD21X10240
It should come with instructions.
GE Triton Model #EDW4000G03WW won't drain danhustonii GE/Hotpoint 1 October 24th, 2007 11:35 AM
GE Triton GSD5130D02WW "Normal" light flashing and beeping. Dread Pirate Roberts GE/Hotpoint 1 September 28th, 2006 03:47 PM
GE Triton XL Stevie B GE/Hotpoint 3 August 17th, 2006 11:00 AM
ge triton III won't drain dvg GE/Hotpoint 3 June 7th, 2006 12:21 PM
GE / Triton Dishwasher Normal Light flashes on display russ GE/Hotpoint 1 December 9th, 2005 10:30 AM
