Results 1 to 2 of 2
Thread: How often do you recharge your fridge freon ?
    WASE4220 is offline Member
    Mar 2006
    ATX
    Exclamation How often do you recharge your fridge freon ?
    Do anyone know when it's time to recharge your fridge freon ? Thx in advance.
    ivoidwarranties is offline Appliance Tech
    May 2008
    on the frying pan
    never if you have a good running unit. most charges last 10+ years if no issues with sealed system. you can't just fill it up if you don't know how, don't have equipment and certification for use of. as long as all other parts are operating correctly- freezer warms up, along with fridge; depending on model the evaporator coils (in freezer) will frost only at top areas and not the rest, indicating sealed system restriction or low freon. depending on age might be warranty issue and also, the freon doesnt just disappear, it most likely would have a leak and putting more freon won't fix leak.
  1. [FIXED] Kenmore Bottom-Freezer Fridge Icing up in Drainpan
    By Hondatudinal in forum Sears Kenmore
    Last Post: May 6th, 2010, 08:04 AM
  2. Replies: 24
    Last Post: September 12th, 2008, 02:41 PM
  3. Kenmore Coldspot freezer perfect, fridge warm
    By nandof in forum Sears Kenmore
    Last Post: July 1st, 2007, 09:49 AM
  4. Replies: 3
    Last Post: April 26th, 2007, 10:27 AM
  5. Jennair fridge side not cold after defrost
    Last Post: September 20th, 2006, 12:48 AM
