Old September 3rd, 2008, 04:39 PM
nospin is on a distinguished road
Default GE wbvh5200j2 Washer won't spin at high speed
I've got a new front loader. During a wash I will frequently notice the drum spinning slowly. The timer might read 14 minutes. The timer counts down to 11 and then the drum stops for a moment and then reverses direction, but the timer shows 14 again. This goes on and on. The load never spins at high speed to remove the water. Is the Automatic Load Redistribution function at fault here?
Thanks.
Old September 3rd, 2008, 07:53 PM
No, thats not likely, as I have a similar model to yours, and mine has never done that once in my 2 years I've owned it.
Since its new contact GE to come out for free under warranty to see whats going on.
Old October 14th, 2008, 09:22 AM
flexjay is on a distinguished road
Smile front load washer
if clothes are out of balance then you will have this problem, along with improper leveling leg installation. machine will try and redistribute the load, and eventually give up. I've seen it many times. proper installation, sorting and loading may be the cure, especially if it spins ok empty. try it and see.
Front Loader won't do high speed spin. djnacory Frigidaire/Electrolux 5 January 8th, 2008 09:21 AM
Washer will not go into high spin "mode" Rupp Sears Kenmore 1 November 26th, 2007 11:19 AM
MAH3000AWW Won't High Speed Spin CWBR Maytag/Magic Chef/Admiral/Jenn-Air 3 December 20th, 2006 01:32 PM
Whirlpool compact two speed washer: Grinding noise on spin... Cherokee Whirlpool/KitchenAid 1 May 29th, 2006 11:55 PM
Frigidaire FWT445GES2 No High Speed Spin rapidtransit1970 Frigidaire/Electrolux 16 February 12th, 2006 01:13 PM
