Results 1 to 4 of 4
Thread: RCA (GE) Dryer is Dead
    Hugg727 is offline Premium Member
    Oct 2008
    New Jersey
    Default RCA (GE) Dryer is Dead
    From what i can see my RCA dryer (Model #BJLR473GVOWW) is a newer GE style dryer.
    It looks like it might be a thermal fuse issue, as i did check the door switch and it seems ok.
    Does anyone know what the proper fuse is and where is it on the dryer?
    I don't see a thermal fuse on this model,
    Check your wiring diagram for one, your wiring diagram is located inside the console control.
  3. The Following User Says Thank You to Jake For This Useful Post:
    Hugg727 (October 8th, 2008)
  4. #3
    Oct 2008
    New Jersey
    I wil try that. What else could it be?
  5. #4
    Check your outlet were your dryer plugs into, get a lamp or hair dryer and plug it in were your dryer is plugged into, if the lamp or hair dryer doesn't work, then the problem is in your outlet or breaker to that outlet.
  1. Kenmore Dryer 417.94072301 No Heat
    Last Post: September 28th, 2008, 10:46 PM
  2. Maytag Dryer Performa Dead
    By JohnA in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 19th, 2007, 01:34 AM
  3. Whirlpool Dryer Model: LEQ9508KQ0 is dead
    By JCNiest5 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 27th, 2006, 10:40 AM
  4. 417.99680210 Laundry Center - dryer dead
    By dromesburg in forum Sears Kenmore
    Last Post: August 18th, 2006, 06:09 PM
  5. Kenmore 70 Dryer - Totally Dead
    By ua_mk_2005 in forum Sears Kenmore
    Last Post: May 27th, 2006, 08:34 PM
