Old November 3rd, 2008, 06:42 PM
Stacy C is on a distinguished road
Default GE Dishwasher with black scum on bottom
I discovered this site when our dryer went out on Saturday, and I'm already back again with a dishwasher problem. When it rains, it really pours.
We have a GE GSD3800G00CC that was brand new when we bought our house five years ago. It ran fine for four years, but last year it started collecting water in the bottom, which resulted in the formation of a blackish green scum. After several months of periodically scrubbing the bottom of the dishwasher, I finally gave in and spent $110 for a technician to repair it. That was two months ago.
In September, a local appliance technician installed a loop in the drain hose and cleaned out the sump. This seemed to have taken care of the problem. However, I noticed yesterday that the black scum is back. Tonight I unscrewed the drain catcher thing on the bottom of the dishwasher and scrubbed everything down again. Unfortunately, it seems the same problem has returned.
I called the technician for help, only to (sadly) learn from his wife that he had a heart attack and a bypass within the last couple of months and is out of commission for a while. (Fortunately, he seems to be recovering ok.)
The technician's wife recommended another guy, but I was hoping the repair would be covered under a warranty. However, she informed me that the work was only guaranteed for 30 days. As it figures, it's been exactly 2 months and 2 days since the service. I'm now concerned this could be a more complex repair that will require us to shell out even more money that we don't have. I really can't even afford to pay another $100 to have it looked at again.
I'm hoping someone can advise me on the following:
1) What could be causing this problem? Is it something we could possibly fix ourselves?
2) If we are planning to try and sell the house in the next year, is it worth paying to have the dishwasher fixed, or should we look at buying a new one? We were thinking of checking out a Sears Appliance Outlet (a.k.a. "Scratch & Dent")
Thank you for your help,
Stacy
Old November 3rd, 2008, 09:02 PM
Hi Stacy,
A common issue on these when they don't drain or don't drain well is a worn out Piston & Nut Assembly. Check that first.
The Piston & Nut Assembly is #564 here(its located inside your dishwasher in the very back):
Here's the Piston & Nut Assembly for your model:
Manufacturer's Number: WD24X10018
WD24X10018
Old November 4th, 2008, 03:11 PM
Default Thank you
I removed the screen and located the piston. I'm assuming that I won't be able to tell if it is worn out without just replacing it, so I went ahead and ordered the part. Hopefully that will take care of it. I will let you know.
Thank you so much! You are a godsend!
Stacy
Old November 4th, 2008, 03:29 PM
Sounds good Stacy, Yes, let us know it that resolves the problem.
Old November 6th, 2008, 09:35 PM
Default Installed new piston
We've installed the new Piston & Nut assembly and run the dishwasher. Out of curiosity, since we've had this problem for so long, is it normal to have a little bit of water left in the bottom of the dishwasher after it has run a cycle?
We do still have a little water in the bottom, but it is clean (right now). We are currently running some dishwasher cleaner through it too see if that helps clean out the interior a little more.
I'm not sure that we'll know if it's fixed until we see if scum appears again in a few more days.
Stacy
Old November 6th, 2008, 10:37 PM
Yes Stacy, a very small amount of water is normal after a cycle, it keeps the rubber pump/motor seal from becoming dried out and cracking.
Keep us posted.
Old November 19th, 2009, 06:18 PM
ADS ADS is offline
ADS is on a distinguished road
Default Same Problem
I have a GE dishwasher, Model No. GSD2200G02BB. I'm having the same problem with the black scum on the bottom. As far as I can tell from the parts diagram (and searching the GE website) there is no piston & nut assembly for my dishwasher (or, at least, that's not what they call it). What is the name and where can I find the parts I need to replace to resolve this problem with my GE model? Please advise.
ADS
Old November 19th, 2009, 07:06 PM
Hi ADS,
Your model doesn't have the piston nut assembly.
What I would do first is remove #506 then #508 here and check to make sure your filter screen isn't clogged.
These 2 dishwasher cleaners are the best:
A great Dishwasher cleaner to get rid of hard water and mineral deposits in the dishwasher:
Citric acid- mineral deposit remover
Removes built-up soap scum and discoloration due to iron and other water impurities. Also works great in washing machines, porcelain sinks and porcelain tubs.
Glisten Dishwasher Cleaner and Deodorizer
Old November 20th, 2009, 03:24 AM
ADS ADS is offline
Thanks for the quick response. I removed #506 and #508 and siphoned out a lot of the water before my original post. I found a lot of black scum, but nothing appeared to be clogged. I'll try one of the dishwasher cleaners you recommend and let you know how it works out.
Regards,
ADS
Old November 20th, 2009, 08:03 AM
Ok ADS, sounds good.
jenn air dishwasher bronze oiled front trade for black glass Mike in KC Maytag/Magic Chef/Admiral/Jenn-Air 3 March 9th, 2008 03:27 PM
Sears Kenmore Elite Dishwasher 665 Leaking from pin holes in bottom ScottSD Sears Kenmore 1 July 21st, 2007 03:38 AM
black residue in dishwasher parrot79 KitchenAid 1 February 20th, 2007 10:52 PM
Dishwasher leaking water at bottom of front door Lighthouse Wife Maytag/Magic Chef/Admiral/Jenn-Air 5 December 29th, 2005 02:01 PM
Hotpoint Dishwasher leaks at bottom DeeDee GE/Hotpoint 2 October 3rd, 2005 11:05 AM
