Results 1 to 4 of 4
Thread: GE Dryer
    Tagman886 is offline Premium Member
    Nov 2007
    NC
    Default GE Dryer
    I have a GE Dryer model DPSR405EA0WW and I know the motor is bad and it calls for a WE17M22. I have a motor with the following number on it 5KH26JJ064S. Will this motor work? I can't find any WE numbers on the motor. I am thinking it will work, may have to change some of the wires where they go on the motor switch.
    Nope, those numbers don't match up with the WE17M22
    I'd be careful changing wires around, may cause you to blow the motor if you accidentally put a wire in the wrong place.
    Why don't you just order a new WE17M22 better safe then sorry.
    Nov 2007
    NC
    I placed that motor on it and everything wired up the same, works like a charm.
    Great, glad it worked Tag.
  1. Kenmore Dryer 417.94072301 No Heat
    Last Post: September 28th, 2008, 10:46 PM
  2. Kenmore electric dryer does not heat.
    By fiabeg in forum Sears Kenmore
    Last Post: June 3rd, 2008, 08:22 PM
  3. GE Electric Dryer runs but no heat
    By vdrsolo in forum GE/Hotpoint
    Last Post: September 27th, 2006, 12:44 PM
  4. Whirlpool Dryer gets Warm not Hot, Takes long to Dry
    Last Post: August 19th, 2005, 08:48 PM
  5. Kenmore 90 Series Gas Dryer Problem
    Last Post: March 15th, 2005, 01:02 PM
