Old February 7th, 2009, 02:10 PM
96rdstr is on a distinguished road
Default [FIXED] Jake-Need some help with diagnosis
GE Model GSD5330D03WW
Serial RA787431B
Some of the buttons on the touch panel are not working. Is there a way to test the control switch assembly to make sure that is the issue?
I believe this is the one that I need.
http://www.repairclinic.com/referral...=1265&N=912020
It has been a while since I have been here. You helped me diagnose and repair my Kenmore Calypso machine a couple of years ago and it has given me flawless service ever since.
Thanks for all your help.
Old February 7th, 2009, 11:03 PM
Hi 96,
Yes, thats the correct part for your model.
Yes, Jeff has a test link for either the Newer or Older model electronics, depending on what yours is:
Read #14 & 15 here:
http://www.applianceaid.com/ge-dish.html
Old February 10th, 2009, 07:43 AM
Thanks Jake.
The problem with the dw is that the Pots and Pans and the Normal Wash buttons do not work. I don't get any beeps or LED indicators. The buttons from Light Wash to the Start all work fine.
Do you think it could be the control switch assembly?
Old February 10th, 2009, 10:47 AM
Yes, thats what I would order.
Don't worry, if you click that link you posted above and order it you have a special 30 day return policy for a full refund, even if you installed it and it didn't fix it, you can just un-install it and return it for a full refund.
Old February 11th, 2009, 08:57 AM
Done deal. Thanks for the help.
I will report back on the fix.
Old February 11th, 2009, 09:35 AM
Ok, sounds good 96.
96rdstr (February 19th, 2009)
Old February 19th, 2009, 08:05 AM
Alright!
I got the part in from the clinic, installed in less than 5 minutes and everything works perfectly.
Once again, thanks for you help Jake
Old February 19th, 2009, 09:43 AM
Excellent 96, good job fixing it.
Changed The Speed Contrrol Board.... FRANK RIZZO Frigidaire/Electrolux 3 July 30th, 2007 05:28 PM
Help In Changing Thermostat Pete V KitchenAid 7 May 24th, 2007 12:42 AM
Jake, I need help dude357 Whirlpool/KitchenAid 5 April 25th, 2007 09:02 PM
Jake, Question. DelieveryMan Whirlpool/KitchenAid 4 March 12th, 2007 08:02 PM
Replaced evenheat CB, no joy. Robert AllThumbs Sears Kenmore 5 November 3rd, 2005 08:52 PM
