February 9th, 2009, 06:37 PM
dryer heats erratically
GE model DDE7200RALWH heats erratically on all cycles; troubleshooting tips would be greatly appreciated.
thanks
February 9th, 2009, 11:08 PM
Pull your dryer away from the wall, then take the exhaust vent hose off, then dry a normal load to see if it fixes it, open some windows if you have the dryer inside your house to let the hot/warm air out.
Because if your vent is clogged or restricted, it will cause a no heat/intermittent heat issue.
If thats ok, then its likely your heating element is going out.
Heating Element
P/N: WE11X103
Dryer Heating Element used on many GE brand electric clothes dryers. Has a coil diameter of 5/8 in. For element restring kit only use P/N WE11X203.
February 16th, 2009, 05:48 PM
Replaced the heating element and still no heat on all settings
. I checked the hi-limit, safety, and high/low drum themostats for continuity and all checked out ok.
I'm thinking maybe the selector switch might be malfuntioning. The tech sheet in the back of the dryer shows (in a black bar-like graph) the different selector switch settings and associated terminals in black. For instance, the cottons setting shows terminals 6-7, 8-7, and 10-9 blacked out....does this mean I should read continuity between all these terminals when the cottons button is selected?
What else should I check????
February 16th, 2009, 07:14 PM
Some of those GE dryers had a problem in the timer where the heat contact inside the timer would sometimes not make proper contact. If you have a amp probe you could check it by wiggling the knob when the dryer does not heat and see if the heat wire at the timer draws amperage or not.
February 16th, 2009, 08:54 PM
Yes, thats true.
Here's the timer for your model:
Manufacturer's Number: WE4X795
Also check to make sure your getting the full 240 volts to your dryer from the power cord, I've seen either the house breakers get weak and start going bad or the 240 receptacle go bad, causing erratic/non heat issues as well.
February 17th, 2009, 04:34 AM
Originally Posted by
Cascade
Which wire is the heat wire and can I check it for voltage instead of amperage? I'm assuming this wire sends 120v to the heating element.
February 18th, 2009, 07:18 AM
Can I jump out the timer wires to determine whether it's good or bad? If so, which ones should I put a jumper across?
By jplante in forum Sears Kenmore
Last Post: May 17th, 2010, 07:20 AM
By jet64155 in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: February 20th, 2009, 08:05 AM
Last Post: September 28th, 2008, 10:46 PM
By Penguin in forum Sears Kenmore
Last Post: November 13th, 2007, 09:50 PM
By AJWatUC in forum GE/Hotpoint
Last Post: September 22nd, 2006, 08:48 PM
