Results 1 to 4 of 4
Thread: Replaced Bulb Under Microwave now no High function
    Rodehog is offline Premium Member
    Feb 2008
    Westchester, NY
    Default Replaced Bulb Under Microwave now no High function
    I have a JVM1650 and I replaced both burnt out bulbs that are under the microwave to iluminate the stove top. After replacement with the factory bulbs I now have only the low setting where prior to the bulbs burning out I had the High & the Low.
    Any help would be appreciated,
    Robert
    Oct 2004
    JVM1650
    That is part of a full model#.
    Damaged board is likely
    Removed the power to the microwave before you changed out the bulbs?
    http://www.applianceaid.com/micro6.html
    NEW Appliance Repair Aid
    http://www.jrappliance.ca
    JRAppliance
    Feb 2008
    Westchester, NY
    Its a JVM1650CB006
    Oct 2004
    Check the backside of the smart board for damage/burnt...
    Power control board
    ...relay could also be stuck ( cannot tell with visual testing ).
    JRAppliance
  1. Dacor 2004 Microwave Model # DMT2420S
    By ginawg in forum Microwaves
    Last Post: November 29th, 2008, 10:47 AM
  2. Microwave Using Tips
    By nancypeterson in forum Microwaves
    Last Post: July 30th, 2007, 04:31 AM
