Results 1 to 2 of 2
Thread: GE Dryer DBL333EB1WW
    Eddmercado is offline Premium Member
    Jun 2008
    Virginia
    Default GE Dryer DBL333EB1WW
    GE model# DBL333EB1WW
    serial # TD701623W
    The dryer tumbbles and moves as normal but is does not heat up at all. Is it maybe the heating element?
    As usual thanks!!
    I'd first check your voltage at the back of your dryer were your power cord connects to it, if your not getting 240 volts access the outside 2 terminals on your terminal block(Red & Black), middle terminal is White(neutral) then its a voltage/breaker issue.
    If thats ok, then I'd ohm your heating element for continuity.
    Here's the heating element for your model:
    Manufacturer's Number: WE14X10015
    icon
    icon
    iconWE14X10015
    Here's a help link to take it apart:
    http://www.applianceaid.com/take-apart.html
    Unplug your dryer first.
  1. Kenmore Dryer 417.94072301 No Heat
    Last Post: September 28th, 2008, 10:46 PM
  2. Erratic Dryer Behavior (MDE5500AYW)
    By Lawrence in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 12th, 2007, 04:20 PM
  3. GE Electric Dryer runs but no heat
    By vdrsolo in forum GE/Hotpoint
    Last Post: September 27th, 2006, 12:44 PM
  4. Whirlpool Dryer gets Warm not Hot, Takes long to Dry
    Last Post: August 19th, 2005, 08:48 PM
  5. Kenmore 90 Series Gas Dryer Problem
    Last Post: March 15th, 2005, 01:02 PM
