Old March 12th, 2009, 03:51 PM
dc2001nj is on a distinguished road
Default Ge Profile Pdw8280jo1ss Drain Problem
I have a GE PROFILE dishwasher and its leaving about a half inch of water in it when it's finished. I checked the lines, I cleaned under the plastic filter cap in the right rear under the water spout . If you hit cancel the water will drain out , except that last half inch. I took the drain hose off under the sink and drained the water out into a bucket. It didn't have alot of pressure behind it but it did drain.
Any help will be appreciated.
Thanks ,
Dave
Old March 12th, 2009, 09:21 PM
Hi Dave,
Your model has a separate drain pump motor, its #325 here:
You have something jammed/clogged in it, or your drain motor impeller inside it is bad.
You may need to pull your dishwasher out to access it from underneath.
Here's the drain pump motor assembly for your model:
Manufacturer part number WD26X10037 is RepairClinic item number 1472739
WD26X10037
Old March 13th, 2009, 10:02 AM
Thank you
Dave
Old March 13th, 2009, 06:35 PM
Glad to help Dave, let us know how it goes.
[FIXED] profile drain problem loterig GE/Hotpoint 2 March 6th, 2009 10:40 PM
Quiet Partner III Drain / Heater Problem alohatech Whirlpool 1 May 1st, 2008 05:06 PM
GE profile PDW8280 drain problem bearwithus GE/Hotpoint 1 November 7th, 2007 04:38 PM
Kenmore Elite HE3 drain problem ninez Sears Kenmore 1 October 16th, 2007 11:19 PM
Model 110.29962(891) drain problem. Tigger#76 Sears Kenmore 9 June 11th, 2006 03:19 PM
