Go Back   ApplianceBlog.com - Appliance Repair Forums > Appliance Repair Talk > Microwaves > GE/Hotpoint
Old March 15th, 2009, 10:35 AM
dwmcqueen is on a distinguished road
Default Turntable motor replacement hood microwave
I have a General Electric JVM1842WF001 that the turntable stopped completely a little while back. After my bolstered success in easily repairing my Whirlpool dishwasher, I thought I would tackle this one.
I removed the bottom cover and and see the motor. It looks rather simple to replace. However, everywhere I look on the web says to make sure the capacitor is discharged before doing any work. How do I ensure this without opening up the rest of the microwave? Do I need to be concerned with this even though I am accessing one easily accessible motor, or is there another way to ensure the same safety?
Old March 15th, 2009, 01:13 PM
TechnicianBrian's Avatar
You only need to discharge the capacitor if you are accessing the high voltage section of the microwave. If you are just replacing the turntable motor, don't worry about it you are safe. Use a multimeter to check for voltage when you run a cycle at the motor to ensure the motor is the actual problem. If it is, replace the turntable motor and then put it back together. If there is no voltage, it is time to look inward for the problem.
TechnicianBrian
AllTechAppliance.com
Old March 15th, 2009, 01:34 PM
Just to make sure I understand - power up the microwave and attach a multimeter at the connector (that connects to the motor) and make sure there is juice to the motor?
Old March 15th, 2009, 02:04 PM
That is correct. Start a cycle with something in the oven cavity and see if you have voltage present.
TechnicianBrian
Old March 16th, 2009, 06:37 AM
Good - just making sure I understood. I tested that and there is current to the motor...motor just doesn't work. Which is good news for me, since it looks like an easy fix.
Thanks for your help!
ultrawave microwave hood - no power mccarron Sears Kenmore 1 November 20th, 2007 05:18 PM
Kenmore Microwave hood 721.80602500 Jack1 Sears Kenmore 0 September 1st, 2007 08:01 PM
kenmore ultrawave microwave hood flabbb Sears Kenmore 10 November 18th, 2006 06:44 AM
Whirlpool Microwave MH6150XHB-1 turntable stopped RockwallMike Whirlpool/KitchenAid 3 October 24th, 2006 07:48 PM
KitchenAid Microwave Hood Combo #KHMS155L feelingrippedoff Whirlpool/KitchenAid 1 July 15th, 2006 11:23 AM
