Old April 5th, 2009, 12:35 AM
loisbarney is on a distinguished road
Default HELP! Can't replace Hotpoint built in oven door
I removed the oven door to clean the oven. Now I can't get it back. I'm sure there's a trick to getting it back and someone out there has found it. Is that you? If you have, I'd appreciate your technical assistance.
I've removed and replaced an oven door on a free standing range, but this is different. The latches keep snapping back and won't engage. I am thinking this is going to be a two person job.
I am in BIG trouble. Thanks in advance.
Old April 5th, 2009, 08:15 AM
We would need the model# of your oven to assist you.
Your model# tag should be located either inside the oven frame or below the oven.
Kenmore model 790.9661* oven door problem hammesd Sears Kenmore 13 October 26th, 2008 09:18 AM
Oven door won't stay in broil position cthompso Frigidaire/Tappan/Electrolux 6 December 21st, 2007 04:30 PM
KitchenAid Superba Double Oven DOOR LOCKED- please help! wilma KitchenAid 3 October 23rd, 2007 10:53 AM
Caloric oven door hinge LibbyS Amana 1 September 13th, 2006 12:36 PM
Kitchenaid Oven Range Door bmattison KitchenAid 1 October 5th, 2005 10:14 PM
