Old June 2nd, 2009, 01:16 PM
tcleveland is on a distinguished road
Default GE Washer #WHDSR209DAWW, gets stuck between Wash and spin
My GE top loading washer will run fine through the wash cycle, the water will drain but the control dial stops here (at the rinse cycle). It makes a very slight humming noise at the dial. I can manually move the dial to the spin cycle and the tub will spin and then finish the cycle. Please help. I'm gonna throw you a good tip for this one. This site is the best and Jake is THE MAN..............
Old June 2nd, 2009, 03:27 PM
So after it drains the water does it spin before the rinse cycle? or just drains then doesn't spin and the dial doesn't move past that?
Sounds like a bad timer to me if thats the case.
Here's the timer for your model, in case you need to order it:
Manufacturer part number WH12X10296 is RepairClinic item number 1168689
WH12X10296
tcleveland (June 3rd, 2009)
Old June 3rd, 2009, 10:07 AM
Thumbs up GE wont go past the wash cycle without having to manually move the dial.
Yes, It does wash, and the water drains out, but it does not spin until I manually move the dial to the spin setting............I will order the new timer right away thanks,............Todd
Old June 3rd, 2009, 09:20 PM
Ok Todd,
Old June 4th, 2009, 12:36 PM
Jake, wheres the best place for me to look for a tear-down schematic regarding swapping out this timer. I looked on repairclinic.com, but didn't get what I was looking for. Is it pretty straightforward? thanks again............
Old June 4th, 2009, 02:43 PM
Ok Todd,
Its fairly easy to replace, just remove the top console screws#11 here, then the console panel#13 will tilt forward, then your timer is #100, just remove the electrical connector from it, then unmount the timer from the control panel, should be 2 screws that hold it in place:
Let me know how it goes.
Old June 10th, 2009, 09:20 AM
Thanks for the schematic regarding changing out the timer. I put the new timer on and the problem was still occurring. I just sent the timer back..........
With the front cover off, I was able to determine that the humming/ buzzing sound was actually coming from what looks like a valve(?) located at the cold water inlet. (I think that it is an electrically activated valve of some kind. Maybe part # 91 on the diagram that you had attached.(?) The part / valve? is also hot to the touch when it is making it's buzzing/humming noise. Would a bad valve cause the cycle to be interrupted if it doesn't let cold water in during the rinse cycle? Thanks for the help.
Old June 10th, 2009, 10:09 PM
Yes, I would definitely say its your water inlet valve thats bad if thats humming and not letting water in.
Its #805 in the parts diagram photo I posted above.
Manufacturer's Number: WH13X10024
WH13X10024
Old June 18th, 2009, 08:06 AM
Default still didn't remedy the problem..............
jake,
Thanks for your help so far. I had tried the timer and the inlet valve and the problem still exists. I installed the new inlet valve and the washer still gets hung up on the rinse cycle. The new inlet valve also made a slight hum/buzzing sound and was hot to the touch on the cold water inlet side. No water enters the tub for the rinse cycle and, subsequently, the wash cycle stops at the rinse phase until the dial is manually moved past the "rinse" step. Any ideas? Thanks, Todd
Old June 18th, 2009, 09:05 AM
Hmm, thats very odd, this may sound silly, but its happened to me before, did you take the cold water side fill hose off and make sure you have good water pressure coming out, get a bucket/container and run it in to see.
Now some of the new fill hoses have a safety pressure valve on them, have you replaced the fill hoses recently?
Other than that I'm stumped as well.
[FIXED] Neptune MAH5500BWW won't wash or spin - error code LO salerno Maytag/Magic Chef/Admiral/Jenn-Air 5 January 6th, 2009 05:52 PM
GE Washer EWA3000B3WW Eterna Stuck on Spin Cycle Buzz Cut GE/Hotpoint 4 January 28th, 2008 03:53 PM
Kenmore Washer 417 Final Spin not Working pennyhoney Sears Kenmore 3 July 12th, 2007 09:49 AM
Maytag PAV1000AWW washer won't spin unless helped erasmusk Washers 5 November 26th, 2006 08:37 PM
Kenmore Washer will not spin all the time a&p Sears Kenmore 5 January 23rd, 2006 10:55 PM
